Hahn's "No Tap" Oil system
Hey, I've been looking at this for a while and I'm trying to figure out how they are returning the oil without tapping the pan/block. Has anyone bought the kit to know where they return to?
Anybody got any pics of the return? I knew the oil feed was through the plug, not sure about where it returns though.
I think the kit is like 140, but if I can figure out what fitting they used I'll just go to lowes and get it.
Haha, what the ****?
I suggested doing that for the return and everyone told me if was a stupid idea. I guess there's no problem with that being too low and under the oil level? That's awesome, I wonder if I can get that size at a lowes or hardware store? Anyone know the size? I'm guessing that's probably going to be hard to find in a store.... Maybe Hahn will sell me just the fitting.
Im pretty sure Hahn will sell you the plug. Looking over by invoice I think it is part number H TZ-5340 I doubt you're going to find a ecotec drain plug with a hole in it at Lowes
I didn't use mine and gave it to a friend for his turbo. it is working fine for him
ask and you shall recieve!
turbo guys love to help turbo guys... it those heaton's that i dont care for
Last edited by hungryhip-ccp; Mar 27, 2009 at 01:55 PM. Reason: Automerged Doublepost
ok they wont tell u how it run but its like this
oil leaves turbo, goes into a tee, small tee leads into the water pump plate on the passenger side of the engine, u can see if witht he wheel off, its held on by 4 10mm bolts, its sort of a circle shaped thing, than the big part of the tee leads into the drain plug fitting, u can make the kit urself for ~20bucks if you go to a hard ware store, u need the following
drain fitting for turbo(with barb'd end)
a tee with the same in/out as yoru turbos fitting, and the tee to be 1/2 the size of the main hoses
a 90* npt to barb fitting, same size as the small tee
hoses
clamps
and than route it all urself
hoses
clamps
a few of those pictures in them selves prove that its a flawed system.
see the oil puddling and dripping from the bottom of the exhasut housing on the 3rd pic?
on a journal barring turbo in witch you use full operating oil pressure(not all journal barring turbos are like this) i could see this possibly working as you'll have enough exiting oil pressure to over come the oil at the bottom of the pan, however on a DBB CHRA this would be epic and total fail. as those CHRA's tend to operate at oil pressures in the single digits.
if this would work, then y would you need the drain plug to have a hole in it itself? considering that youd have to unscrew the fitting either way to drain your oil. or just unclamp and pull off hose
He is now using a new engine and new turbo with a proper oil return. Can you guess why he went with an entirely new setup?
