HARROP TVS, What You Need To Know & FAQ
Old 05-27-2010, 11:18 PM
  #201
csementuh's Avatar
Aight man, well good luck. The 2.8 and smaller feels pretty good. The 2.7 and 2.6 are even better than a 2.8
I'll have to see how the TVS feels when I get it Tues and go from there. I have a feeling I'll be buying 80#'s and a pulley after awhile.
Old 06-07-2010, 04:56 PM
  #202
csementuh's Avatar
Anyone know what the 'safest' TVS pulley is on a 'stock' longblock. Still running stock springs, head bolts, head gasket, etc, and I'd like to pulley down without popping it.
Old 06-07-2010, 05:40 PM
  #203
roderick's Avatar
I am runing the TVS with a 2.8 pulley, 80s and E85 and my Injector duty cycle is right at 95% so with gas you could easly run a 2.6 with the 80s.
Old 06-07-2010, 06:07 PM
  #204
csementuh's Avatar
Great to know thanks. I am mainly concerned with boost and cylinder pressure on the stock engine however, but I presume that is too highly variable to really know a 'safe' limit
Old 06-07-2010, 11:13 PM
  #205
RooTBeeR's Avatar
whats ur afr at?
Old 06-08-2010, 06:21 PM
  #206
Zach06CobaltSC's Avatar
A lot of it really has to do with KR. What people fail to realize on pump gas is that conditions change daily. Temps change, cyl temps change, etc. Just because one day you don't have any KR, doesn't mean the next you won't. When you start to run high high boost applications this really starts to come into effect. You could probably get away with running a 2.6 tvs with lower amounts of timing. If you planned on doing this though I would highly recommend e85. I have personally ran a 2.7 tvs and e85 and the car was absolutely amazing. My injectors, 80lbers, were maxed at 6grand though. I plan on running 98lb injectors shortly and a 2.6 pulley on the tvs to put down some great hp/tq numbers. The difference between pulley drops and gas to e85 is absolutely amazing =D.
Old 06-08-2010, 06:54 PM
  #207
roderick's Avatar
Originally Posted by RooTBeeR
whats ur afr at?
My 95% idc was when I was running 11.5 air fuel or 7.5 e85 air fuel.
Now I am running 11.7 air fuel or 7.7 e85 air fuel.
Old 06-08-2010, 09:26 PM
  #208
RooTBeeR's Avatar
yikes, so what did ur idc% drop to @ 11.7(7.7)?
Old 06-08-2010, 09:42 PM
  #209
roderick's Avatar
its right at like 93% not alot of a drop but still safe to run.
Old 06-08-2010, 09:45 PM
  #210
RooTBeeR's Avatar
haha, im still on the 3.15 and 91octane @ 11.8afr and only at like 80%
Old 06-08-2010, 10:30 PM
  #211
roderick's Avatar
Yeah I was at like 70 on gas with stock pulley and 60s. Somthing like that. We should add to this thread the pulley size and IDC people see with that pulley on gas and e85.
Old 06-08-2010, 10:33 PM
  #212
RooTBeeR's Avatar
yeah, might be a good idea
Old 06-08-2010, 10:57 PM
  #213
WickedSS2005's Avatar
There are a lot of factors to that tho. My fuel pump rewire lowers it a little. AFR changes IDC, then you have methanol and fuel type.
Old 06-09-2010, 01:13 AM
  #214
RooTBeeR's Avatar
exactly...just like boost from one car to another will be diff
since ls4 TB is out of the question, would a ported stocker help?
so which fitting to i weld on the PCV? -10an or -12an?
oh and anybody think itd be worth it to mount like 1-2 of these http://www.jegs.com/i/Derale/259/16307/10002/-1 to this http://zzperformance.com/cobalt_ion/...=895&catid=178 to help keep iat2's down/more constant wether at idle, cruising, or wot?
Old 06-09-2010, 12:03 PM
  #215
csementuh's Avatar
Did you buy a fuel pump rewire or did you make one? I'd like to try and make one since a relay and a few wires doesn't seem worth $35. I'm not sure if I actually need one, but I guess it couldn't hurt...
Old 06-09-2010, 04:58 PM
  #216
-10an for the pcv
Onlt cost of shipping, $5. I tested for OTTP and took the pics for install directions
Last edited by WickedSS2005; 06-09-2010 at 04:59 PM. Reason: Automerged Doublepost
Old 06-09-2010, 11:25 PM
  #217
csementuh's Avatar
^ Good deal. I put together a pump rewire tonight and hopefully I can install it this weekend. Might help at high RPMs to keep a steady flow to the rail. What size fuse are you running on the inline fuse? 20? 25? 30?
Old 06-10-2010, 08:36 AM
  #218
roderick's Avatar
Let me know how that works. I am out of fuel in my car 4th gear at 6300 rpm.
Old 06-10-2010, 09:02 AM
  #219
Josh@ottp's Avatar
$35 is too much for a harness?
Old 06-10-2010, 09:13 AM
  #220
csementuh's Avatar
I'll be intstalling it with my 80's this weekend probably. You are also running E85 on a smaller pulley however so it's not a very good comparison. If I get a change to install the rewire first and log with my 60's I will, but if not I won't have a basis for comparison with the 80's.
I didn't say it was 'too much', I said it was 'not worth it', I should have worded it as 'not worth it to me'. I had the parts essentially laying around and the know how to make it, so free > any money. That wasn't a rude comment towards OTTP (especially since other vendors sell the harness for the same amount, and I've been super happy with the stuff I've bought from you). You're also basically the only vendor who ever answers questions. Sean is impeccable with answering PM's, and I believe I've talked to you on the phone before. So don't act like I've insulted you, it's all good. =)
Old 06-10-2010, 09:21 AM
  #221
Josh@ottp's Avatar
I'm not insulted. New price is $29.99 http://www.ottperformance.com/store/...-Kit-9p918.htm
zzp used to sell their kit for $50 before we made one. FYI
Old 06-10-2010, 09:39 AM
  #222
csementuh's Avatar
OK Good, because OTTP rocks!
Those 'other guys' have always given me a problem, and I've bought tons of stuff from them. They hassled me like crazy after a $10 Interceptor 'SS' face I bought got lost in the mail, and it took then a couple of months to send me a new one.
Old 06-10-2010, 09:49 AM
  #223
RooTBeeR's Avatar
-10an for the pcv
Thanks!
good price!
Old 06-23-2010, 10:28 AM
  #224
csementuh's Avatar
Soo.. How 'safe' is it to run a 2.8" on a TVS on an other wise stock engine? All cooling mods except meth, don't want to run meth... OK with a conservative tune, or is that insta piston & head gasket death? Think I'll be OK so long as I keep an eye on IAT2's and KR?
Old 06-23-2010, 10:35 AM
  #225
ebristol's Avatar
Its perfectly fine on a very conservative tune...
But your car wont make any power because you will only be able to run 15-16 degrees of timing. If you try to run more timing your car will knock like Jehovah's Witness.
Quick Reply: HARROP TVS, What You Need To Know & FAQ
