How to make a Mod cold air?
Old Dec 19, 2011 | 04:13 PM
2.2CobaltLS's Avatar
how can i mod my cold air on my 2.2 cobalt ls... i dont wanna spend 300 on a cold air
Old Dec 19, 2011 | 04:20 PM
06cobalt racer's Avatar
half price!!!
DC SPORTS COLD AIR INTAKE SYSTEM 05-07 COBALT 2.2L | eBay
well almost half of 300
Old Dec 19, 2011 | 04:32 PM
TurboTechRacing's Avatar
Check to make sure that intake is even in their hands... We will leave that at that...
Honestly there is a reason why intakes cost as much as they do, the companies have dyno's and a lot of equipment to design and test these. There have been many times, cheap intakes are nothing more than tubing... Which is great for a low price, but when they make you LOOSE power... You will then realize, after you waste $$$.
Do it once, do it right.
Old Dec 19, 2011 | 05:02 PM
nhanson's Avatar
ZZPs intake tube with a good filter
Old Dec 19, 2011 | 05:04 PM
padlock's Avatar
you can find intakes for $120ish shipped on here if you look.. thats where i got mine
Old Dec 20, 2011 | 06:04 PM
Leafydialupking's Avatar
Though some of those reputable brands are just as big of snake oil salesmen as the ebay guys, just that they have a better rep. I call it the FRAM mentality, brand with a great rep that sells rubbish products and just keep selling them.
Most of the times those companies just make what fits into the spot. the smart ones keep the MAF tube the same size and try to do what length tuning that they can. As long as the maf tube is kept the same diameter and is put in a spot that makes sense you wont lost any power, just might not gain any. Though even getting an AEM or Injen, you might not gain any power.
Old Dec 20, 2011 | 06:06 PM
You come from a cavalier, what yousay is true is for a cavalier, as it does NOT have a MAF sensor... Good luck with your therory with a Cobalt...
Heck even some of the name brands cannot get the air flow right, and codes are thrown... There are a select few intake over the last 6 years that have been proven by OFRUM members, not vendors, on what works and what doesn't.
Old Dec 20, 2011 | 06:09 PM
Yes and the ones proven not to work, change the maf tube diameter or put the maf in a bad spot (or otherwise cause turbulent flow near the maf).
Old Dec 20, 2011 | 06:11 PM
Go for it, get an ebay intake and try it, you will toss it in the garbage, or atleast a ben franklin bill... Heck members have posted that they actually LOST HP by ebay intakes in the past.
Cavaliers CAN use a pipe, and call it good, Cobalts cannot. Cruzes only have 1 good intake, the K&N! Injen and all the other brands dont work.
The smart members ones know, by research and read results from other members. (So dont call it a salesmans speach, when it is coming from the lips of a consumer)
Old Dec 23, 2011 | 05:54 AM
09LAP's Avatar
ya go spend 300 on a RAM and shove it up your A**
all others: this guy is worthless
https://www.cobaltss.net/forums/2-2l...estion-266620/
Old Dec 23, 2011 | 05:55 AM
09LAP's Avatar
https://www.cobaltss.net/forums/2-2l...estion-266620/[/QUOTE]
read above link for worthlessness and if you wanna see the full story hit up the LAP section
Old Dec 23, 2011 | 05:58 AM
heathkidder's Avatar
iv got a injen intake can be used as cai or short ram i was thinkin 175
Old Dec 23, 2011 | 09:44 PM
Ownedbyagirl?'s Avatar
I got the high flow tube from zzp for 100$ and the drop in K&N filter.... also the Air box silencer removal mod.
What a differnce it did for me!
Old Dec 23, 2011 | 09:53 PM
David6312008's Avatar
I built my own using 3 inch piping with a MAF adapter and a 3 inch rubber elbow connecting it to the intake and have gained 1 to 2 mpgs and the engine has much less lag up hills.
Old Dec 24, 2011 | 05:12 AM
kingg5's Avatar
these parts cost what they do because vendors put a 100% mark up on what they pay.
06MetallicBalt
Jul 20, 2025 08:47 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
Stuff
Oct 1, 2015 05:47 PM
OrangeCoba
Sep 25, 2015 06:06 PM
