Launch control on ss/sc
Old Dec 26, 2008 | 03:38 PM
EXsoccer1921's Avatar
Okay, i know about the N2MB 2step, but 2steps aren't allowed in my class. so i posted up a question in the tech seciton on the local track forum and got this as a response
The 2008 rules say this for clutch cars...
Clutch launched, stick shift vehicles may use line lock on starting line to prevent vehicle from rolling. Clutch launched, stick shift vehicles may use single stage rev limiter to control starting line RPM.
You wire the rev limiter to a micro switch on the clutch pedal. When you let go of the clutch, the limiter switches off and frees up
the engine. A line lock switch can also be wired to the clutch pedal. Clutch down and loc is on.
To do it right, you'll need a power on/off switch to the limiter and to the line loc as you don't want either one working all the time.
You could also wire the limiter to a button on the shifter, or the steering wheel. Let go of the button when you let go of the clutch which is mechanically simpler then wiring to the clutch.
If you don't let go of the button and you launch with the limiter on...it will be like a stutter box and that is grounds for disqualification.
can someone chime in here and lend some advice on how a "launch control" could be wired up like this using a line lock. and before you go explaining a line lock, i already know what it is hahah. i'm just asking how you would go about setting this all up.
i'l like to have a seperate on/off switch so i can drive it on the street but have it activated on the track. and i would like, when its switched on, to active the line lock when the clutch is pushed in
Old Dec 26, 2008 | 03:57 PM
Area47's Avatar
Rent me! per hour
it can be done through hpt, however. it is a fuel cut. so the risk would be yours if you want to do it that way or not
Old Dec 26, 2008 | 04:00 PM
well it has to be wired and visible. thats the thing
Old Jan 1, 2009 | 07:44 PM
Old Jan 2, 2009 | 09:23 AM
06SS ALL DAY's Avatar
bump for this guy good question... i just wonder how you can do that in hpt...
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Coballin13
Sep 25, 2015 08:43 AM
