Meth injection problems
Old Mar 10, 2013 | 09:23 AM
usafcobalt's Avatar
Well hopefully I can get some insight here. I just installed the boost activated meth kit from snow performance. I have not done any tuning whatsoever! Prior to spray my afr at wot. Was 11.5. Now when it sprays I see 11 until approx 2 psi before max boost. Then it jumps to 13.5-14. I'm running 4gph nozzle. -20 washer fluid and 2 bottles of heet pergallon. Now I'm assuming due to the cooler charge I'm boosting more. I was reading 14. Now I'm seeing 16. Thanks guys
Old Mar 10, 2013 | 10:07 AM
Bad-A-SS's Avatar
Get tuned asap
Your not gonna gain much without getting tuned so might as well
Old Mar 10, 2013 | 10:11 AM
usafcobalt's Avatar
Your missing the point though. I know I need to retune. I should be running rich though. I shouldn't have to add fuel when I'm already adding it
Old Mar 10, 2013 | 10:17 AM
Omnigear's Avatar
is that even a 50/50mix....
Old Mar 10, 2013 | 10:45 AM
Cherry GT's Avatar
^^ no its not, it would take 3 12oz bottles of HEET to make it a 50/50 mix.
Old Mar 10, 2013 | 11:01 AM
usafcobalt's Avatar
Haha well that could be the problem then figured had to be a mix problem. Ill add a bottle today and let you guys know. Thanks for the help. I just went off that mixture from google. Guess I deserved that.
Old Mar 11, 2013 | 02:13 PM
06cobalt racer's Avatar
here is the best way to make a 50/50 mix...
take a jug of washer fluid, make a line where the fluid level is, pour out half of it in a clean container. add 3 bottles of the yellow heet. fill up the washer fluid jug with the stuff you poured out till it reaches the line you made. put remaining fluid in your washer fluid in your car.
and done....perfect 50/50 mix
Old Mar 11, 2013 | 02:40 PM
usafcobalt's Avatar
Yeah that's kinda what I did. I got my afr right now. Mix was deff the problem thanks to all for the help.
Old Mar 11, 2013 | 03:40 PM
Area47's Avatar
Rent me! per hour
fwiw, you can show really lean and be pig rich in actuality.
Old Mar 11, 2013 | 03:43 PM
that mix is really important, dont just pour more heet into the jug you already have, do what 06cobalt_racer said, ive been doing it just like that for over a month now no issues
Old Mar 11, 2013 | 04:14 PM
i have read this about 10 times lol. can you explain?
Old Mar 11, 2013 | 04:35 PM
Cobalt/ss's Avatar
Can you gis help me.. 2
Its a cuestion . Lol
Old Mar 11, 2013 | 04:44 PM
usafcobalt's Avatar
Yeah that would be the reason I put a wide band In so I have accurate afr readings. Yeah I mix it out of the car. It's not fun to drain or fill either! I hid everything in the passenger fender.
Old Mar 11, 2013 | 04:51 PM
Cobalt/ss's Avatar
I have problems with mi boost
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
