Methanol problem/question
I have the throttle body spacer tapped for meth, when my car is at idle it's still sucking in meth. The AFR is at 10.0 but when we pull the line at idle it's at 13-15....anyone know what could be wrong...we have the meth running off of boost kicking in at 9psi...
bump really no one has any idea?
did you do all the wiring correct? how long has it been in the car and what brand?
Yes the pump doesn't kick on, until 9 psi. i think it's just sucking the access thats in the line...just installed it lastnight and its a snow performance progressive
did you purchase the optional solenoid? I have the aem kit it comes with a check valve to prevent seapage. The snow kit looks like there is no checkvalve in it so you would need to by the solenoid separate and I'd suggest you disconect the meth until you get it. I'm in the process of having Vince tune mine too bad he's on vacation for a week..... I've got my start psi at 5 and full at 20psi you being an sc I can't really help you there!
yeah the wiring. and you need a check valve at least. go over everything you have done.
ok thanks, i will go buy a check valve...
Originally Posted by Armyguy151
(Post 5149045)
(Post 5149045)
Originally Posted by Witt
(Post 5149062)
The check valve in my kit was defective as was another local guy's. Bought an inline brass one from some vendor and never had a problem after that. I plumbed mine in right before the nozzle.
just place the check valve close to the nozzle. I have mine directly into my 90 degree nozzle holder
man i went to home depot and lowes and couldn't find shit..i did get something like a check valve but it's huge....:lol: i'm going to piece it together and see if it works
Yea Most all cars need a solenoid or a check valve to keep from having issues. Once you get one it will solve your issues.
Originally Posted by devilsown
(Post 5153235)
