Methanol problem/question
Old Aug 7, 2010 | 03:41 AM
Armyguy151's Avatar
I have the throttle body spacer tapped for meth, when my car is at idle it's still sucking in meth. The AFR is at 10.0 but when we pull the line at idle it's at 13-15....anyone know what could be wrong...we have the meth running off of boost kicking in at 9psi...
Old Aug 7, 2010 | 11:40 AM
Armyguy151's Avatar
bump really no one has any idea?
Old Aug 7, 2010 | 11:43 AM
MP Cobalt's Avatar
did you do all the wiring correct? how long has it been in the car and what brand?
Old Aug 7, 2010 | 11:59 AM
Armyguy151's Avatar
Yes the pump doesn't kick on, until 9 psi. i think it's just sucking the access thats in the line...just installed it lastnight and its a snow performance progressive
Old Aug 7, 2010 | 12:14 PM
turbaltss's Avatar
did you purchase the optional solenoid? I have the aem kit it comes with a check valve to prevent seapage. The snow kit looks like there is no checkvalve in it so you would need to by the solenoid separate and I'd suggest you disconect the meth until you get it. I'm in the process of having Vince tune mine too bad he's on vacation for a week..... I've got my start psi at 5 and full at 20psi you being an sc I can't really help you there!
Old Aug 7, 2010 | 12:21 PM
MP Cobalt's Avatar
yeah the wiring. and you need a check valve at least. go over everything you have done.
Old Aug 7, 2010 | 12:24 PM
Armyguy151's Avatar
ok thanks, i will go buy a check valve...
Old Aug 7, 2010 | 12:32 PM
turbaltss's Avatar
when you install it put it as close to the nozzle as possible too!
Old Aug 7, 2010 | 12:40 PM
Witt's Avatar
The check valve in my kit was defective as was another local guy's. Bought an inline brass one from some vendor and never had a problem after that. I plumbed mine in right before the nozzle.
Old Aug 7, 2010 | 12:47 PM
Armyguy151's Avatar
so you cut the line say about 5 inches from the inlet and just connected a check valve? where can i buy one at
Old Aug 7, 2010 | 02:11 PM
MP Cobalt's Avatar
just place the check valve close to the nozzle. I have mine directly into my 90 degree nozzle holder
Old Aug 7, 2010 | 03:24 PM
Armyguy151's Avatar
man i went to home depot and lowes and couldn't find ****..i did get something like a check valve but it's huge.... i'm going to piece it together and see if it works
Old Aug 9, 2010 | 05:59 PM
devilsown's Avatar
Yea Most all cars need a solenoid or a check valve to keep from having issues. Once you get one it will solve your issues.
Old Aug 9, 2010 | 07:10 PM
Armyguy151's Avatar
Yeah I called snow today and it's 50.00 for the part... ty for the help
WickedSS2005
118
Dec 18, 2012 02:44 PM
