All New Aluminum Tank Straps Included With Every Trunk Mount Water Methanol Injection
Non Authorized / Non-Supporting
ATTENTION SUPERCHARGED AND TURBOCHARGED COBALT SS OWNERS!!!
Installing our trunk mount water alcohol injection system just got easier! All new black anodized aluminum tank straps are now included with each rear trunk mount system!!! This replaces the previously supplied adjustable rubber straps which were included with each system.
Many companies sell water/methanol injection systems. However, these other companies offer what is called a "water methanol injection kit". These "kits" are just that. A box containing all the parts separately that must be first assembled before they can be installed on your vehicle.
Only AlcoholInjectionSystems.com offers a water alcohol injection system that comes 100% pre-assembled, pre-wired and completely ready-to-install - right out of the box! Whereas our competitors systems can take up to 4-6 hours to assemble and install, the pre-assembled water/methanol injection systems from AlcoholInjectionSystems.com can generally be installed and operational in an 1 hour!
This not only saves you time and frustration but also helps eliminate the chance of you possibly assembling or wiring the system incorrectly and damaging it.
In addition, each and every methanol injection system from AlcoholInjectionSystems.com is pre-tested to make sure that it works properly before it‘s packaged. Imagine spending an entire afternoon assembling a water methanol injection kit only to discover that it is defective! With AlcoholInjectionSystems.com, we try to make sure this never happens. We hand test each system before it’s packaged to ensure that it works and functions properly before we ship it out to you. No other company provides you with such service!
It pays to deal with AlcoholInjectionSystems.com.
Stage 1 Adjustable Boost Activated Trunk Mount $369.99
Stage 2 Adjustable Progressive Variable Input Trunk Mount $599.99
Also available, we now offer fully assembled stainless steel braid hose kits replacing the entire plastic fluid line. These stainless steel hose kits come fully assembled with swivel fittings swedged on for you. All you need to do is attach the line. Stainless steel hose kits are $109.99
