Mike25's custom 2.4 turbo build
Old Mar 22, 2008 | 10:46 PM
mike25's Avatar
Mike25's custom 2.4 turbo/engine build
well i figured id start up one of these threads and keep it updated along the way...ive gotten alot more parts since the last time i posted up in....heres what i have so far:
UPDATES: POST #'S 16,68,124 and 162
turbo and manifold together...i had to test fit the studs and everything
studs ended up having to be cut down in three spots:
piping and couplers/t clamps:
this is for the compressor outlet:
heres the intercooler from treadstone (28"x6"x3.5"):
this is the ic mounting plate...still has to be welded on:
and heres all my fittings, line and gaskets:
so far ive got everything mechanical i need minus the bov and dp....i still have to pick up my electronics as well as the injectors....car goes in bright and early monday morning to have the downpipe made so well see how things go...ill update this thread as things progress....enjoy
Old Mar 22, 2008 | 10:51 PM
ralliartist's Avatar
sweet. what turbo is that?
Old Mar 22, 2008 | 10:52 PM
mike25's Avatar
garrett t3/t4 50 trim w/stg3 wheel....however there will probably be someone in here that says it doesnt matter if its a stage 3 wheel or not
Old Mar 22, 2008 | 10:54 PM
sweet, you should make some good power with that. What is your goals?
Old Mar 22, 2008 | 10:59 PM
mike25's Avatar
i would love to hit 300hp with this...thats my ultimate goal...i screwed up when i ordered my wastgate and got the wrong spring...so it looks like ill be running about 12 lbs of boost...i remember looking at the sols on 50's and they were running about 250 at 8psi...although its hard to compare them and doesnt really sy much
Old Mar 22, 2008 | 11:03 PM
sols? what car is this going on? and all you gotta do is get a boost controller.
Old Mar 22, 2008 | 11:06 PM
mike25's Avatar
cobalt...from what i understand a boost controller will only control boost from the springs level and up...not down
Old Mar 22, 2008 | 11:11 PM
celicacobalt's Avatar
12 psi should be fun. thats what i would like to run. im just worried how the tranny will hold up. i peak at 9 psi right now.
Old Mar 22, 2008 | 11:20 PM
mike25's Avatar
yea what im worried about most is the clutch...which i know will go...but im going to baby it for a while to i can pick up a stage 3 or something...im not sure what ill do yet....im not so worried about the tranny itself, its all in how you drive it...as with the auto...you should be fine as long as your running a tranny cooler
Old Mar 22, 2008 | 11:54 PM
oh, I didn't realize that you wanted less boost. I thought you were upset cause you wanted more boost.
Old Mar 22, 2008 | 11:56 PM
Mnatvyc1223's Avatar
what type of turbo is it?
Old Mar 23, 2008 | 12:02 AM
mike25's Avatar
garrett t3/t4 50 trim...lol no i think 12 is pushing it to begin with
Old Apr 12, 2008 | 12:43 PM
mike25's Avatar
well i just test fitted the intercooler on the car with the plate welded on and its fits like a charm...ill have to take a day and make the ic piping...not sure when thatl be...but things are coming along nicely
Old Apr 12, 2008 | 12:49 PM
Red2.4SS's Avatar
Cool! Sounds like it is comming along nicely! Post some more pictures when you get a chance!
Old Apr 12, 2008 | 03:47 PM
mike25's Avatar
will do...i didnt get a chance to take a pic of the ic on the car because it started raining....but i can tell you it looked awesome! i havent gotten to buy anymore parts lately because of that damn downpipe....should be paid off after this weds when i get paid
so far i still need:
BOV
injectors/harness
spark plugs
3 gauge pillar
wideband
MBC
and a damn maf bung
well i went outside and got alot better look and did some test fitting after the rain stopped....the throttle body inlet is 2.75" in diameter...i have a rubber(not silicone) 90 bend thatl fit on it so ill use that....tb/ic side i figured i might be able to do it with 2 90's and a u bend to come off of the ic and around through the plastic gap on the side.....as for comp./ic side i should be able to get by with 2 75's a 90 and maybe a straight....so ill have to take a weekend and cut everything up and make it fit nicely.....and as for taking off the stock intake i did that in about 5 minutes so i dont know why everyone was having problems with that a while back
Old Apr 24, 2008 | 03:29 PM
mike25's Avatar
Update
well today was a nice day and i had some time so i decided to do the ic-tb side piping....i will say this was my first time taking the bumper off and it all went smooth except for the F***ing bolts that connect the bumper to the front quarter panels....
as for piping itself heres what i came up with...
i was able to kind of flex the pipe and silicone to make it meet up...thats why you see some tiny gaps between the couplers and pipe....the two 90 bends are rubber...anyways i think the t-clamps will probably pull everything tight
Old Apr 24, 2008 | 09:55 PM
Jn2's Avatar
Jn2
found the thread, thanks for showign me this, now i kno which pipes to get, will be orderign intercooler and pipes this saturday, wil post pics
Old Apr 24, 2008 | 10:06 PM
b_faulk75's Avatar
This looks awesome, i can't wait to see the final outcome!!! Keep up the good work!!!
Old Apr 24, 2008 | 10:18 PM
mike25's Avatar
thanks....it was defintately some work getting that bumper off...but it was my first time so that may have had something to do with it...anyways...im hoping the couplers will allow some slight bending...seeing as standard size pipes wont make it meet up perfectly...the pipes only took about a a half hour to cut
Old Apr 24, 2008 | 10:22 PM
b_faulk75's Avatar
Hey mike, you gonna make it to carlisle???, i'd love to see this in action.
Old Apr 24, 2008 | 10:26 PM
mike25's Avatar
didnt know anything about carlisle....when and whats going on?
Old Apr 24, 2008 | 10:28 PM
b_faulk75's Avatar
https://www.cobaltss.net/forums/north-east-56/carlisle-performance-style-may-9-11-official-rollcall-98632/ i know it's coming up fast, but here is some info...
Old Apr 24, 2008 | 10:32 PM
mike25's Avatar
damn theyve paved it since i wast at the vette show a few years back....anyways id love to come to it but the car more than likely wont be ready by then...id be up for a different meet if one could be organized sometime in june or something
Old Apr 24, 2008 | 10:43 PM
b_faulk75's Avatar
https://www.cobaltss.net/forums/deleted-threads-89/ocean-city-md-meet-89188/
Old Apr 25, 2008 | 12:25 AM
mike25's Avatar
now that i mite be down for
