My HTV1320 dyno #'s
My HTV1320 dyno #'s
Well, spent about 2 hour on the dyno
ok, before HTV
2.85" pulley, zzp shorty header, 3" dp w/ high flow cat, dc sports cat back, aem intake.
246 whp, 230 tq
after
all mods as listed above plus htv1320 w/ 2.9"
290 whp 258 tq
got some videos on my digital camera, need to upload em.......a little more spark and I should be able to get to 300 pretty easy, running about 13-14 degrees timing now
ok, before HTV
246 whp, 230 tq
after
290 whp 258 tq
ok, before HTV
246 whp, 220 tq
after
290 whp 258 tq
ok, before HTV
246 whp, 220 tq
after
290 whp 258 tq
You're running the 80mm pulley (middle one?)? If so, I think those are pretty good gains. 50whp and 38wtq is pretty nice gain for running the same size pulley (roughly, but still larger) that you had on. I'd like to see the graphs when you are able to upload em.
yes, dyno was the same dyno
IAT2's were about 140 a wot at the end of the session
next is some cooling mods, h/e coming soon....and I can probably up a degree or 2 of timing...300 is very possible
it's the 75mm pulley
140 is very good for no cooling mods and being on the dyno for 2 hours..!
Very nice numbers! Congrats, and I know you will hit 300+whp with a couple more tweaks to the tune easily.
I find your data interesting in comparison to my twinscrew data from back in August since you are on the same size pulley I was. The IAT2's were right where you're at and all I had for cooling mods was the dual pass plate. Also, my IDC's were right where you are at as well at 87%. I had a little more timing and made 272whp, but with my 2.6" setup I made 236whp on the same dyno. You have pretty much made my day with all your info. Thanks!
well, the tune probably has 300 in it easy.....fuel is nice and steady now, only thing left is maybe a few degrees of timing to see what happens, not to mention the nice h/e I have going on......but there was a very nice increase over the m62 w/ the 2.85
