My Slowbalt .... RUNS!!!
Yes its true,
after more than 200 hours of labor I have successfully rebuilt the motor and got it working again W00t
just have to bleed clutch (dam linkage wont stay on tranny without leaking air)
torque crank pulley
tighten downpipe
replace wheels
drive till im arrested
torque crank pulley
tighten downpipe
replace wheels
Originally Posted by bdwarr6
Yes its true,
torque crank pulley
tighten downpipe
replace wheels
torque crank pulley
tighten downpipe
replace wheels
na i wont blow it again im going to be able to monitor it alot better this time and have plenty of mods to keep heat down if i ever feel like installing my cobra HE thats next to my car, or taking off my ic plate to get the fitting welded into it.
Honestly i just want to drive the car for a few days then ill fiddle with it
I havent even put in any of my torque braces or poly mounts
YESSS!!! Congrats man. I just pulled my motor an hour ago. Saturday i will seperate the head and install new sleves and pistons. Glad to hear it works man. I will definately keep in touch for any new questions I may have.
Originally Posted by 07BlackCobalt-LS
Ok seriously you should get sound clips or Video up now....
Good work and
You're a pioneer to use all
******* Awesome Man! Glad to hear she finally breaths octane and air again! Now, the real tinkering begins. Have fun driving it, as you it's great to finally reap the results of all your hardwork and effort!
Time will tell, I will ask my friend at GM what he thinks about the loss of an oil squirter and see what he says...
Its running and that's where it's at! Too bad you couldnt have the hole drilled/tapped out more and use a bigger banjo bolt to hold the squirter!
