OFFICIAL Blown 4-banger build updates!
Old 04-08-2009, 09:25 PM
  #2426
WSFrazier's Avatar
I thought you just needed new lifters/valvetrain?
I hope you didn't pull the motor just for that...
Or did something else fail? I have never facepalmed anyone more than you and Ralliartist over how you guys fail at modding cars.
WSFrazier is offline
Old 04-08-2009, 10:01 PM
  #2427
SSdan's Avatar
Take me off that haterade list, I feel your pain.
SSdan is offline
Old 04-09-2009, 12:26 AM
  #2428
Blown 4-banger's Avatar
You're already at the top of my haterade list, why you care so much about other peoples ****, is beyond me...
P.S. I didn't pull the engine for lifters.
Everything with my engine was done properly. It was a series of things stupidly going wrong that cause the issue that made me pull the engine.
After reading your PM, you are officially off my haterade list.
Blown 4-banger is offline
Old 04-09-2009, 12:41 AM
  #2429
WSFrazier's Avatar
Lol, then why even make this thread?
Uh huh... Perfect sense. I believe if it was done properly, you would be driving the car, no?
Old 04-09-2009, 01:10 AM
  #2430
PM sent...
Old 04-09-2009, 03:49 AM
  #2431
Texas SS's Avatar
cant wait to see the final result man
Texas SS is offline
Old 04-09-2009, 12:19 PM
  #2432
WunSick's Avatar
So whats the status cam? Hit me up on AIM today, yack it out.
WunSick is offline
Old 04-14-2009, 01:05 AM
  #2433
Well, I was planning on keeping this under wraps, but **** it. I don't care anymore. So I tore the motor down today. Number 1 and 4 rod bearings were pristine, number 2 bearing was scored pretty good, would have been destroyed in a couple minutes had the engine been left running. Number 3 rod bearing was mostly in powder form at the bottom of the oil pan. Some of it was still hanging on to the crank journal.
Here is the oil pan, decorated nicely with bearing powder and oil. I like to call it, Magnetic Mud
Here are some of the larger pieces of bearing left in the oil pan.
Here is the largest piece of bearing recovered. Pretty!
Due to the thrashing (while brief) from the rod, the corresponding main bearings were punished pretty good. Crank is fine, all 4 rods and pistons are fine. The head gasket was showing signs of trying to blow (been reused some 4 times, it lived a nice life.... *moment of silence), so new head gasket will be needed. Other than that, everything else was peachy. Valvetrain was untouched.
The cause of failure has been determined as moderate to severe detonation in cylinders 2 and 3. The Pistons (while still healthy) took quite a beating from detonation, and the spark plugs were ghost white. Strangely though, cylinders 1 and 4 were the opposite. Pistons showed signs of running stupid rich, and spark plugs were black. My wideband is closest to the #4 cylinder, and it showed it as running rich. My EGT sensor was in the #4 primary, and showed readings that went along with running rich. However, since the second my engine came to life the second time, my O2 sensor never worked. I checked all wires, I cleaned it, I even got a new one. Nothing. It never worked. So we pretty much came to the conclusion, that the computer was for some reason running 1 and 4 uber rich, and 2 and 3 uber lean (causing detonation). I only had the car running 13-15 degrees of timing. So, its the only explanation I can come up with at this point. So, it was 100% not assembly error. ENGINE WAS ASSEMBLED PROPERLY AS STATED BEFORE!!! So there is my latest update, enjoy
Old 04-14-2009, 06:17 AM
  #2434
06blackg85ss's Avatar
damn man, well at least the valvetrain was ok..
06blackg85ss is offline
Old 04-14-2009, 12:14 PM
  #2435
I guess there is always some positive to the negative. Its only gonna cost me like $180-200 to get it back together. All machine work will be labor free, so thats also a plus.
Old 04-14-2009, 03:03 PM
  #2436
Tomtwtwtw's Avatar
Why would it run so differently in the cylinders though? You didn't put the coils back in the wrong order, did you?
Tomtwtwtw is offline
Old 04-14-2009, 03:10 PM
  #2437
In order to put the coils in different spots, it would require cutting and resizing the harness We didn't do that, as far as I know. I'm gonna take the injectors to a local shop, and have then checked to make sure there not fucked up. Then I'll probably sell them, because I'm gonna use stock injectors while NA, and when I go turbo I'll use 83 lbs/hr injectors. So the 60s will be retired.
Old 04-14-2009, 06:36 PM
  #2438
they probably got shitted up sitting out in the open in your engine compartment for so long. They varnish up or get a little dirt in em and it's game over
Old 04-14-2009, 09:28 PM
  #2439
Greased's Avatar
if you had the cash it would be 10000000000x better to run some secondary injectors.
Greased is offline
Old 04-16-2009, 03:12 AM
  #2440
They sat in my room, sealed in a zip lock bag, for the entire time my car was down.
No it wouldn't. Race cars don't use secondary injectors. The cobalt isn't my DD anymore (thats what my AE86 is for), so I don't give a **** about drivability, or gas mileage anymore (not that I did in the first place).
Old 04-16-2009, 06:11 AM
  #2441
still not the best way, you did completely clean em out before you stored them correct?
Old 04-16-2009, 08:28 AM
  #2442
Greased's Avatar
race cars dont use stock wiring harness/ stock ecu as well
Greased is offline
Old 04-16-2009, 08:51 AM
  #2443
SSdan's Avatar
Holy **** cam. That's some carnage right there.
How come the gasket was reused so many times? It was a cometic right?
SSdan is offline
Old 04-16-2009, 01:06 PM
  #2444
No. I didn't know you had to clean them out before storing them. If they worked when I pulled them out, I didn't see any reason they wouldn't work after sitting in a sealed clean plastic bag
Yeah, but that doesn't matter. The problem with huge injectors, is they have a minimum pulse width that is longer than what the car needs to maintain a 14.7:1 AFR at idle, so the injectors idle at minimum pulse width, but the car still runs really rich at idle. There are some 1400 RWHP Supras out here in AZ, they use giant ass injectors, and idle at 11.5-12:1 afr.
Cause I'm cheap, and the gasket was given to me. It was a cometic yes. I'm just gonna get another cometic.
Old 04-16-2009, 03:02 PM
  #2445
YEah you really need to completely drain injectors before storing them for extended periods of time or they "gum" up.
As for large injectors, the 79lb/hr ones I run idle better than stock, but anything more than that is pretty shitty for low PW idle.
THat's also why I run 550cc primary and 1600cc secondaries in my rx-7, still idle it @12.4-12.5:1 afr.
Old 06-07-2009, 03:30 PM
  #2446
damien's Avatar
Any news?
damien is offline
Old 06-13-2009, 12:57 PM
  #2447
freakta's Avatar
wow you arent having much luck, hope it all turns out ok
freakta is offline
Old 06-30-2009, 08:53 PM
  #2448
Originally Posted by damien
Any news?
Read signature...
Old 06-30-2009, 09:47 PM
  #2449
383_Stroker's Avatar
I've not read anything but the first and last page of this thread. But in response to the statement that 1 & 4 were rich and 2-3 were stupid lean.
When i put my 60# injectors in i had what sounded like an air leak, but couldn't find it, so i decided it was just a noise the new injectors made. Tuned it to my desired afr..
Like a week later i had my dad listen to the sound, and he suggested i pull the injectors back out and check the o-rings. Turns out two of the o-rings on the injector cups had been pinched and were sucking air around them. I had a similar plug reading (2 rich, 2 lean). So when i replaced the o-rings, my wot afr went from 11.8 to off the scale rich (below 10.0)..
Perhaps something similar happened to you?
383_Stroker is offline
Old 07-01-2009, 03:28 AM
  #2450
Na, it was just bad luck. **** happens. I'm just going to get it back together, and get rid of it.
Quick Reply: OFFICIAL Blown 4-banger build updates!
