oil filter relocation
Old Jul 31, 2011 | 10:58 AM
zfissette's Avatar
just curious if anyone has cut off the stock oil filter section of the motor and installed a remote oil filter? that and an alternator relocate would make it possible to run a real custom intake with full length lami cores. so basically, move the alternator to the ac position and fabricate a idler pulley and bracket for where the alternator used to sit.
Old Jul 31, 2011 | 11:23 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
I have done the remote oil filter on my DD (damaged oil filter housing in shipping) and it isn't worth the time and money to do. It was a nightmare and if your's isn't broken don't bother.
Old Jul 31, 2011 | 11:46 AM
zfissette's Avatar
id like to build a real custom intake and the oil filter housing is one of the two things in the way, if you have pictures of the finished project i would really like to see them, just to see if it creates the amount of space im picturing.
Old Jul 31, 2011 | 12:06 PM
I will try to find the pics. I had a hard drive die but I should still have them somewhere.
Old Jul 31, 2011 | 12:54 PM
Thanks to photobucket here are the pics.
Old Jul 31, 2011 | 05:30 PM
zfissette's Avatar
that is friggin awesome, exactly what i want to do, im sure there was suffering along the way but it looks completely legit as a finished product. i assume the key is the plate youve bolted where the filter housing used to be to convert the irregularly shaped passages into tubes. it must make oil changes much simpler as well. thank you so much for taking the time to post these photos. does the oil cooler seem to make much difference? cooler engine? oil holds up better? im going to install the phenolic intake spacer shortly so im slightly concerned about engine cooling, if this mod helps with that at all its even more reason to do it.
Old Jul 31, 2011 | 06:06 PM
When you remove the oil filter housing you also remove the stock oil cooler mounting points so you have to use an aftermarket oil cooler. The upside is that you have cooler oil as it isn't already heated up as it is with the stock oil cooler.
The plate that you refer to is available from Bates Engineering so that is an easy part of the puzzel.
There weren't to many places to put the remote oil filter considering the other mods that I have under the hood and routing the braided lines was a bit challenging.
If all of the needed work doesn't bother you and you have someone who can professionally remove the stock oil filter housing then you are a good candidate to do that mod. I know I should have done a 'how to' but it was really crazy with everything going wrong with my project car as well as the DD. Perhaps you can do one in case someone else wants to do it too.
PS I no longer have this mod on my car because after all of that work, the jbp engine blew up 180 miles after start up. Another fellow in the US now has that mod on his car.
Old Aug 1, 2011 | 06:31 AM
Speedytec's Avatar
Similar thoughts here, as this would open up some possiblities for a properly effective intake manifold and also lower some mass of my SC engine. (I have a light rear engined car...)
Something like this should do: BOE Fabrication - Lotus Elise, Exige, and Evora Performance ECM Tuning Products
Tried several options, but our cast oil filter is a major hurdle for a lowered SC...
This plate solution works (angled hose connections should be a bit tighter), but for me the housing removal (block machining...) is simply too much effort for a still unproven gain.
2nd best option:
Replace/lower the alternator and "stretch" the current manifold design in that direction with longer laminova cores inside. And maybe by swapping endplate connections to the other side you could win some length at the filterside too.
Maybe one day....
Old Aug 1, 2011 | 09:18 AM
zfissette's Avatar
the engine failure didnt have anything to do with oil starvation i hope? that just gave me pause for a second lol. angling the ports seems like it might make a little more room but mostly i didnt want to have to consider changing the oil filter when designing the intake.
no_ss
Oct 18, 2015 11:58 PM
Trav3480
Oct 1, 2015 08:17 PM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
