Sleeve-less Ecotec Block - LHU
1 Attachment(s)
So with all this talk about aftermarket sleeves an filled blocks it seems like GM finally stepped up to the plate and said check mate.
http://i48.tinypic.com/j9u7pl.jpg As a comparison. ZZP's http://shop.zzperformance.com/store/...&bw=600&bh=600 Darton's https://i655.photobucket.com/albums/...leevechris.jpg Stock Attachment 49800 |
Interesting . . . . . .
very nice, about time they think ahead
what car does that motor exactly belong to? am not sure |
Regal Turbo/GS
GM calls the LHU a high performance version of the LNF.
thats even more interesting. so those motors, you just do head gasket, pistons, rods, cams, big turbo and all the boost you want? :)
Not really new, or more robust. As a matter of fact the 944 Turbo's that I'm used to were like this. At higher boost levels the blocks were sent out to be sleeved for better rigidity. Nice to see they didn't leave the top of the block open......
That's a nice sandcast block, but can't see the liners? It probably doesn't have some sort of nikasil bore coating on the aluminium, right?
(Lot's of mods on that engine!!) |
Originally Posted by Speedytec
(Post 6783011)
That's a nice sandcast block, but where are the liners? Or does it have some sort of nikasil coating on the aluminium.
Eric you modding your buick already or didya done blow it up??
That is allot more confidence inspiring block!
anyone know if that is a direct swap for LNF or LSJ block? |
Interesting
Originally Posted by slapbetcommissioner
(Post 6783080)
zzp had 4 of these for sale, complete with rads, pcms, harnesses, turbos and all. prices was cheap, like $2799 or something.
My worry is how will just the aluminum hold upto 30+ psi? Not having a steel sleeve in there
^ and the wear characteristics when using alternate fuel and lots of boost?
Interesting...
(Post 6783182)
yea I know the coating and what not. Just currious as how it will hold up for longevity as well as strength
Well we got guys out in the field with turbo sleds making over 300hp without issues. Look at all the turbo street bikes and such on you tube haha.
Looking it up and reading a bit it looks like a lot of the bmw's and the gtr's, lambos come with this coating from the factory. However underground, ams and some others are switching to a sleeved block for high hp builds.
Ya I'm sure if you were going for insane power, sleeves would be the way to go.
Doesnt mean this wont be a good upgrade if it will work out for us.
(Post 6783182)
Originally Posted by 09BlueBaltSS
(Post 6783186)
(Post 6783424)
The block should be able to swap to an lsj or lnf. it's a block stripped out there the same and i believe the new regal are lnf's still
| All times are GMT -4. The time now is 01:55 AM. |
