Sleeve-less Ecotec Block - LHU
Old Nov 7, 2012 | 11:16 AM
ebristol's Avatar
So with all this talk about aftermarket sleeves an filled blocks it seems like GM finally stepped up to the plate and said check mate.
As a comparison.
ZZP's
Darton's
Stock
Old Nov 7, 2012 | 11:17 AM
SylverSS/SC's Avatar
Interesting . . . . . .
Old Nov 7, 2012 | 11:29 AM
jonathan923's Avatar
very nice, about time they think ahead
what car does that motor exactly belong to? am not sure
Old Nov 7, 2012 | 11:36 AM
LS6Rally's Avatar
Regal Turbo/GS
Old Nov 7, 2012 | 12:51 PM
ebristol's Avatar
GM calls the LHU a high performance version of the LNF.
Old Nov 7, 2012 | 01:21 PM
thats even more interesting. so those motors, you just do head gasket, pistons, rods, cams, big turbo and all the boost you want?
Old Nov 7, 2012 | 04:44 PM
Dawgz83948's Avatar
Not really new, or more robust. As a matter of fact the 944 Turbo's that I'm used to were like this. At higher boost levels the blocks were sent out to be sleeved for better rigidity. Nice to see they didn't leave the top of the block open......
Old Nov 7, 2012 | 06:52 PM
Speedytec's Avatar
That's a nice sandcast block, but can't see the liners? It probably doesn't have some sort of nikasil bore coating on the aluminium, right?
(Lot's of mods on that engine!!)
Old Nov 7, 2012 | 06:54 PM
cmiller8006's Avatar
Originally Posted by Speedytec
That's a nice sandcast block, but where are the liners? Or does it have some sort of nikasil coating on the aluminium.
What I want to know exactly as well.
Old Nov 7, 2012 | 07:22 PM
Powell Race Parts's Avatar
Eric you modding your buick already or didya done blow it up??
Old Nov 7, 2012 | 07:28 PM
slapbetcommissioner's Avatar
That is allot more confidence inspiring block!
anyone know if that is a direct swap for LNF or LSJ block?
Old Nov 7, 2012 | 07:36 PM
Interesting
Old Nov 7, 2012 | 07:42 PM
BlkWdoSS's Avatar
that is my question right there and where can I get one lol
Old Nov 7, 2012 | 07:55 PM
OttawaMark's Avatar
zzp had 4 of these for sale, complete with rads, pcms, harnesses, turbos and all. prices was cheap, like $2799 or something.
Old Nov 7, 2012 | 08:25 PM
My worry is how will just the aluminum hold upto 30+ psi? Not having a steel sleeve in there
Old Nov 7, 2012 | 08:28 PM
09BlueBaltSS's Avatar
^ and the wear characteristics when using alternate fuel and lots of boost?
Old Nov 7, 2012 | 09:17 PM
Cobalt_SSTuner's Avatar
Interesting...
Old Nov 7, 2012 | 10:23 PM
Bluelightning's Avatar
Got Bewst?
Well newer sleds, atv's and motorcycles don't run sleeves. They run what's called a Nikasil coating. It actually also gives a much better heat conductivity than cast iron sleeves. I would assume that's what this is. I work at a powersports dealership and people boost the crap out of stuff without issues haha.
Old Nov 7, 2012 | 10:40 PM
yea I know the coating and what not. Just currious as how it will hold up for longevity as well as strength
Old Nov 7, 2012 | 10:50 PM
Got Bewst?
Well we got guys out in the field with turbo sleds making over 300hp without issues. Look at all the turbo street bikes and such on you tube haha.
Old Nov 7, 2012 | 10:54 PM
Looking it up and reading a bit it looks like a lot of the bmw's and the gtr's, lambos come with this coating from the factory. However underground, ams and some others are switching to a sleeved block for high hp builds.
Old Nov 7, 2012 | 10:57 PM
Got Bewst?
Ya I'm sure if you were going for insane power, sleeves would be the way to go.
Old Nov 7, 2012 | 11:00 PM
Doesnt mean this wont be a good upgrade if it will work out for us.
Old Nov 7, 2012 | 11:56 PM
mrbelvedere's Avatar
it will last just fine nissan has been doing this on some of their engines
Old Nov 8, 2012 | 12:07 AM
MP Cobalt's Avatar
The block should be able to swap to an lsj or lnf. it's a block stripped out there the same and i believe the new regal are lnf's still
