Stage 2 upgrade and a jumpy front
Old Apr 2, 2008 | 08:36 PM
drdee's Avatar
Wink Stage 2 upgrade and a jumpy front
I have recently put the stage 2 injectors, GM approved, on my 2006 cobalt ss, I have a lowing kit already, when I accelerate quickly the front tires start vibrating or jumping. My son, who has been upgrading several cars (Jetta etc.) says I need different motor mounts because the factory stock give more and they don't hold the torque on the engine with the upgrade. Is this possible? If so are there new mounts I can order that are GM approved?
dr dee
Last edited by drdee; Apr 2, 2008 at 08:38 PM. Reason: spelling is not an asset for me
Old Apr 2, 2008 | 08:40 PM
chris88z24's Avatar
It's wheel hop. There's no mounts that are GM approved (that I know of). Let off the gas when this happens unless you want snapped axles and a cracked transmission bellhousing that GM won't cover under warranty. Search about, theres tons of info how to launch these cars and on how to fix the hop as well.
Old Apr 2, 2008 | 09:20 PM
INFE's Avatar
yea wheel hop is very bad! it ruins the tranny.
Old Apr 2, 2008 | 09:23 PM
rockkrawler628's Avatar
GM wont do any work to the car if it has motor mounts and trans mounts...
Old Apr 3, 2008 | 12:24 AM
LopsidedJester's Avatar
Around June or so GM should (finally) have a new set of axles out for the LSJ cobalts that is inspired by the LNF cobalt axles and they are supposed to eliminate wheel hop. If you're patient then those should alleviate the problem.
Stiffer trans mounts help a lot, a motor mount helps more in conjuntion with the trans mounts, but you can find a set trans inserts and a motor mount at TurboTechRacing.com , or ZZPerformance.com for fully replaceable polyurethane billet aluminum mounts.
Old Apr 3, 2008 | 12:44 AM
rukkee's Avatar
GM is going to have LSJ specific axle jester? that would be great !
Old Apr 3, 2008 | 10:10 AM
thats why i'm holding off on all aftermarket traction mods. I was told its the same axle as the LNF, but different spline and length due to their different knuckle configuration.
Old Apr 3, 2008 | 10:13 AM
Texas SS's Avatar
yup wheelhop
i have Ingalls dampner
helps alot with wheelhop
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
