tq specs
anyone know the tq spec for the flywheel bolts and pressure plate bolts? thanks in advance
The flywheel is something like 25 ftlbs + so many degrees. I dont remember though. I know that dont help but its not just a straight torque number because the bolts are torque to yeild meaning they are one time use only. I put ARP bolts in my car and they get torqued down to 50 lbsft.
(Post 6213399)
I just bought some ARP Flywheel bolts, and am also wondering what the torque specs would be on them. The stockers are 39 ft/lbs + 25 degrees. But since the ones i have are not torque to yield i'm not sure of the required torque specs to hold my flywheel on reliably
**Update: after i did a search (duh) on my flywheel bolt part # i found ARP's specs, here is for all if you are interested as well. These bolts only cost $26 ARP 4AG flywheel bolts (part number 203-2802): Blister pack contents: 8 flywheel bolts, instructions Torque spec: 58 ft*lbs (with ARP moly lube), 63 ft*lbs (with Loctite), 85 ft*lbs (with 30wt motor oil) Source for torque specs: ARP technical rep from 800 line** |
