tq specs
Old Dec 16, 2011 | 06:57 PM
StevesBlack06's Avatar
tq specs
anyone know the tq spec for the flywheel bolts and pressure plate bolts? thanks in advance
Old Dec 16, 2011 | 09:08 PM
cmiller8006's Avatar
The flywheel is something like 25 ftlbs + so many degrees. I dont remember though. I know that dont help but its not just a straight torque number because the bolts are torque to yeild meaning they are one time use only. I put ARP bolts in my car and they get torqued down to 50 lbsft.
Old Dec 16, 2011 | 10:09 PM
im sure its a higher spec than that... also, i have ARPs and the heads are to tall to use them. im stuck using the factory ones.., kinda sucky but im not making big power any more so i really dont care.
Old Feb 22, 2012 | 11:55 AM
LopsidedJester's Avatar
I just bought some ARP Flywheel bolts, and am also wondering what the torque specs would be on them. The stockers are 39 ft/lbs + 25 degrees. But since the ones i have are not torque to yield i'm not sure of the required torque specs to hold my flywheel on reliably
**Update: after i did a search (duh) on my flywheel bolt part # i found ARP's specs, here is for all if you are interested as well. These bolts only cost $26
ARP 4AG flywheel bolts (part number 203-2802):
Blister pack contents: 8 flywheel bolts, instructions
Torque spec: 58 ft*lbs (with ARP moly lube), 63 ft*lbs (with Loctite), 85 ft*lbs (with 30wt motor oil)
Source for torque specs: ARP technical rep from 800 line**
Barkleyj605
Oct 24, 2015 12:07 AM
yellowsupercharged06
Sep 17, 2015 04:40 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
TurboTechRacing
Dec 14, 2005 05:07 PM
