Wtf!!!! anyone with a lc-1
Old Jul 21, 2008 | 09:26 PM
mike25's Avatar
Angry Wtf!!!! anyone with a lc-1
ok im trying to figure out how to wire up this damn lc-1 to my car.. can someone make sense of this crap?:
2 Mounting and Wiring the LC-1
1. Find a suitable location under your vehicle where the LC-1 body can be mounted. Using
zip ties or other suitable method, fasten the body of the LC-1 device securely to the framerails
or other mounting points as far away from the heat of the exhaust system as the sensor
cable allows. DO NOT zip-tie the LC-1 by the cables.
2. Route the cables from the LC-1 (except sensor cable) into the car interior under the dash.
3. LC-1 Cable connections:
A. Interface and power cables with 6 stripped ends*:
a. Red 12V supply
b. Blue Heater Ground
c. White System Ground
d. Yellow Analog out 1
e. Brown Analog out 2
f. Black Calibration wire
B. Serial In connection, 2.5mm stereo (female) marked as IN
C. Serial Out connection, 2.5 mm stereo (female) marked as OUT.
* 3.1 If you have an LC-1 with only 7 stripped ends the wiring is as follows:
a. Red 12V supply
f. Green Analog Ground
g. Black Calibration wire
4. Connect the RED wire to a switched 12V source in your car. A switched 12V source
goes on as soon as the ignition on the car is on. Make sure the connection is fused with a
minimum fuse size of 5A.
5. The BLUE and WHITE wires should all be grounded to the same ground source.
Optimally, these (and any other MTS device ground) will be soldered to the same lug, and
connected to a single point. When this isn’t possible, connect each one to a separate lug,
and attach in close proximity. Multiple lugs on the same bolt is not optimal, and can result in
unwanted signal “noise.” When possible, soldering is always better than crimping. Please
see chapter 2.3 for more information on Electrical Grounding Concerns.
6. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one or
both of these wires are not being used isolate and tape the wire(s) out of the way. The default
analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is
a simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR. Note: The LC-1’s heater ground and system ground wires should share the same
grounding location of the analog input’s ground. Refer to chapter 2.2 for recommended
wiring schematics.
7. Optionally connect a momentary push-button switch between ground and the BLACK
calibration wire. Please refer to section 2.1.
Note: The use of the calibration wire is not necessary if the LC-1 is connected to Innovate
Motorsports’ XD-16 digital gauge. If the wire is not are not being used, isolate and tape the
wire out of the way.
I DO NOT UNDERSTAND THIS PART AT ALL:
- 5 -
8. Optionally connect a indication LED (1.2-2.2V, 1-30mA is recommended) between the
calibration wire and ground. Please refer to section 2.1
2.1 Indicator LED and Calibration button hookup:
The LED will communicate the LC-1’s status. To monitor LC-1 status, connect the red wire
(Anode) of the included LED to the calibration wire (black) of the LC-1 and connect the black wire
(Cathode) of the LED to the ground wire of the momentary switch. The grounds to both the
cathode side of the LED and the Push button should be connected with the Heater ground.
a. Note: The included LED will fit the following hole size and panel thickness: a 5/32”
(0.155” - 0.158”) hole size and a panel thickness of 28–16gauge (0.031” - 0.062”).
b. Optionally, any 1.2V - 2.2V (1mA- 30mA) LED may be used. A typical LED has 2
wires called Anode and Cathode. The Cathode side is typically the shorter of the 2
wires or the black wire.
Pressing the push-button or connecting the black wire to ground (a three second press is
required with firmware version 1.10) starts a free air calibration process in the LC-1. MAKE SURE
THE SENSOR IS IN FREE AIR FOR THAT. See chapter 4 for details.
Old Jul 21, 2008 | 09:46 PM
pjk91's Avatar
its not that bad.
power to a power source. make sure its a clean source
ground to a lug. nothing else should be grounded to this same lug.
the led must also be grounded to the SAME PIECE OF METAL the power ground is connected to, but to a different lug.
brown wire = 0-5v analog output (connect to HPT box for logging, i think hole #4 if i remember correctly...ground the HPT box too)
Old Jul 21, 2008 | 10:00 PM
theneelster's Avatar
this is the thick black part between the gauge and the o2 sensor...mount it where it won't hang down and free from elements.
route the cables from the lc-1 to your drivers side (most people go up through the shifter location, you could wire it into the engine and through the grommet near your driver's side if the wire is long enough.
a. Red 12V supply
a. Red 12V supply
Okay...check your wires look at the pictures...each ground should be individually grounded with it's own terminal, don't daisy chain the grounds; you can ground to the engine ground just use split loom all the way from the connector to the ground. Tap a switchable 12v power source or a direct 12v with an inline switch and fuse inline (several options here). The analogs are to run the a/f ratio into something like an interceptor pretty straightforward. The rest of the wires are for the gauge I'd assume.
calibration wire. Please refer to section 2.1. Note: The use of the calibration wire is not necessary if the LC-1 is connected to Innovate
simple push button switch at walmart or autozone for like 4 or 5 bucks...says it's not necessary.
- 5 -
This portion is about a signal light to show that the lc-1 is working (I suppose)...sort of like a broken fuse holder's led except in reverse...led lights when working properly...optional so if you can't do it's not wholly important.
Oh and MAKE SURE THE BATTERY is off during the install. You only learn by doing, this should be a good project, it's pretty straight forward. Use solder for the extensions and terminals if at all possible.
Originally Posted by pjk91
its not that bad.
He can use a ground bracket for the grounds...I actually use an ace hardware metal shelving bracket...classy! If there's interference with the lc-1 you can always unbolt the grounds and ground it somewhere else.
Last edited by theneelster; Jul 21, 2008 at 10:00 PM. Reason: Automerged Doublepost
Old Jul 21, 2008 | 10:06 PM
Darkmanx's Avatar
lol it aint that hard .
Old Jul 21, 2008 | 10:18 PM
mike25's Avatar
no its not hard at all...this is the part that gets me:
is it saying that both the ground(black wire) of the led and the push button need to be hooked up the heater wire, or is it saying that once you connect the push button/led together, that the second wire comming off the push button is the ground and that needs to be hooked to the heater wire?
Old Jul 21, 2008 | 10:26 PM
BRN169's Avatar
It was a piece of cake, think it through and you will be fine... Make sure you follow the directions on the gauge and connect it to LC-1's brown wire not the yellow wire as shown in the LC-1's instructions... The yellow wire caused my gauge to freak out when I first fired it up... Also make sure you carefully follow the calibration instructions read it, read it a second time, think it through and read it while you are doing it... I spent a total of about three hours installing mine this past weekend.
CA triple gauge A-pillar
Wideband calibration button and led
LC-1 installed under the hood
You need to parallel the LED with the switch between the LC-1's black wire and ground with the LED's red wire connected to the LC-1's black wire and the LED's black wire to ground...
Old Jul 21, 2008 | 10:33 PM
mike25's Avatar
this is how i have it
lc-1 black wire>led red wire thenled blak wire>left side of push button and then right of push button>blue heater ground
Old Jul 21, 2008 | 10:40 PM
BRN169's Avatar
no no no...
LC-1's white and blue, LED's black and one side of the switch to ground (same lug if possible)
The LC-1's black wire connects to both one leg of the switch and the red wire from the LED. The LED and the switch are not wired in series they need to be wired in parallel!!!
Old Jul 21, 2008 | 10:44 PM
Doc's Avatar
Doc
you are so gonna laugh about how easy this is and how you over thought this whole thing.....
Old Jul 21, 2008 | 10:48 PM
mike25's Avatar
no no no...
ok...im sorry but i dont understand this stuff much....where does the 2nd leg of the switch connect to? and can i connect the leg/black lc-1 wire and red led wire all together at one point?
oh i will...i was the same way when i wired up my boost/oil gauges...
BRN169's Avatar
Maybe this will help, I modified the diagram to show how to wire the switch and led...
Old Jul 21, 2008 | 10:50 PM
mike25's Avatar
**** ok i get what your saying the white/blue lc1 wires+ the black wire if the led and one side of the switch all connect at one point
Old Jul 21, 2008 | 10:59 PM
Doc's Avatar
Doc
watch this
thread on installation and problematic issues can be seen viewed here
Instructions manuals courtesy of Innovate Motor Sports on LC-1 installation
Instructions manuals courtesy of Innovate Motor Sports on DB Gauge installation
source
Old Jul 21, 2008 | 11:53 PM
mike25's Avatar
ok so heres what i got:
Old Jul 21, 2008 | 11:57 PM
BRN169's Avatar
Now connect the white wire to the leg with the blue wire and ground them at one point.
Remember you can't solder them together in advance because the switch gets mounted from behind the panel and the LED gets mounted from the front of the panel...
Old Jul 22, 2008 | 12:02 AM
mike25's Avatar
and thats it? other than wiring the rest of them up? white has to be grounded with the blue wire setup?
im not too worried about that...ill just drill the hole to the exact size of the led and put a little bit of glue on from behind
Old Jul 23, 2008 | 01:19 PM
mike25's Avatar
i was reading through the guide and it says that the yellow wire is a narrowband hookup and the brown is a 0-5v...question is if the gauge needs the brown wire then how the hell am i suppose to use it to hookup to hpt
Old Jul 23, 2008 | 01:30 PM
pjk91's Avatar
i recommend not using the lc-1 as a narrowband + wideband because it's difficult to setup properly. get a new bung welded for the wideband and use it solely as a wideband.
Old Jul 23, 2008 | 01:42 PM
mike25's Avatar
well i have the bung welded in. im trying to figure out this thing hooks up to hpt....i was told i need a 0-5v output...how can i do this when the gauge needs the 0-5v output as well?
Old Jul 23, 2008 | 02:01 PM
pjk91's Avatar
youwould have to loop the connection through the HPT pro box. Basically, the HPT box would have to be permanently mounted in the vehicle somewhere. The HPT box will take the input, and it also has the capability to output simultaneously. Someone correct me if I'm wrong, I never attempted doing it that way.
My AEM shows on the gauge while simultaneously logging on hpt.
Old Jul 23, 2008 | 02:02 PM
mike25's Avatar
so basically id have to unhook the 0-5v from the gauge to hook it up to the box?...then again what if i was to splice the wire into two connectors...like add on a piece of the same gauge wire and then branch off of that
Old Jul 23, 2008 | 02:11 PM
pjk91's Avatar
not sure if that would affect the voltage or not, i never tried it. Might work though. get a meter and try it.
Old Aug 1, 2008 | 06:35 PM
rrutter81's Avatar
i dont even use that switch.... such a waste of time.
ground the calibration wire for 3 seconds and your done.
Old Aug 4, 2008 | 12:41 PM
mike25's Avatar
the data logging wire of the lc-1 is the brown wire right? i think i accidentally confused it with the yellow wire...now i have to switch them.
Old Aug 4, 2008 | 02:05 PM
csementuh's Avatar
That is correct... The brown wire is 1-5v, the yellow with is only for a narrow band. I just installed my LC-1 with a DB-Red gauge last friday before Dan tuned me. Yea the one analog output is a bitch. When I met Dan and he pulled out his HPT box I was like yea you can use these black headphone jack looking plugs right..? Needless to say I spent the next few minutes pulling apart my A pillar and getting the brown wire off my gauge. Soo yea, if you want to have a wideband gauge and tune at the same time, you will need to split the wire or disconnect it temporarily...
