Your methanol setup
alright, i DID search around for this, and only came across info about methanol injection.
what i'm lookin for is, people that have methanol injection. what mix are you running, in combination with what nozzle, where did you put the nozzle. and lastly....why are you running that mix. |
Good questions
im running a 50/50 mix (meth/distilled water). I using the 3 gph nozzle and i have it tapped into the piece that connects the intake to the supercharger....Im running a 50/50 mix cause thats what the tuner reccommended...
50/50 Mix (closer to 70/30 in the winter). 5 gph Nozzle. Injecting into the intake tube.
I'm running the 5gph because I bought a 3, 5, and 7 and desided to start out with the 5... and I'm pleased with the results so I've not changed it. |
Dual 3gph nozzles. I'm running 50meth/50 washer with is like 66% meth.
I am thinking of going with a bigger jet and injecting pre turbo. |
so all of you guys are injecting pre throttle body?
Yeah
70/30 mix......which is -20 washer fluid and 4 bottles of heet.
7gph nozzle. about 4 inches from the TB on the intake. |
is there a reason you guys are spraying before the tb??? i've got a spacer that i was going to use, obviously it'll be after the tb
Well, lol, im sure the main reason why most of us that are spraying before the TB is because we dont have the spacer.
Doesnt matter though. Works the same way. |
I'm not sure if it applies to these cars but in other makes its better to spray post throttle body because it kills the TPS sensors on some cars.
I'm running 50/50 I get methanol from a place 26 miles north of here for 2.80 a gallon then I get distilled water from the grocery store and mix my own. Far less expensive than using the snow performance or devils own premixed stuff which is 40-50 shipped to your door for only 4 gallons. I go through a gallon a week, which could be in part to the large nozzle, a leak, or evaporation since my tank is not completely sealed due to my filler neck project not being completely finished. Previously I would have to take out my headlight to fill the tank, pump is in the drivers side fenderwell. So I made this filler neck to make things easier and I also now have a special funnel with a brass fitting on the bottom that screws right on for leak free filling. http://rodimus.sinisterimages.com/methfiller1.JPG http://rodimus.sinisterimages.com/methfiller2.JPG http://rodimus.sinisterimages.com/methfiller4.JPG http://rodimus.sinisterimages.com/methfiller3.JPG http://rodimus.sinisterimages.com/methfiller5.JPG http://rodimus.sinisterimages.com/methfiller6.JPG I use a Rebel Auto Worx LS4 adapter plate with a 1/8NPT tap and a AEM water injection kit, 550cc nozzle the biggest one with the AEM kit http://rodimus.sinisterimages.com/ls4_3.JPG |
5gph nozzle, right before coupler going to blower, 90/10 mix because bryan said so lol
Originally Posted by burnrubr88
(Post 3919604)
nice, good thing i got the space too lol, but i did just get the stage 2 meth kit from devils, pretty easy to install your self guys???
I recommend starting off with a 50/50 mix of methanol and distilled water. We did lots of testing and for most people this will make the best power while keeping things safe with your tune.
i got 4 1gph nozzles and a 50 / 50 mix but i have an extra spot for one more nozzle just in case
i guess i should take pictures of mine now huh
I'm using the ottp spacer between the tb and sc. 3gph nozzle, running a 30/70 mix since I'm only at 20* timing. When the weather is cool I see 11.2afr at redline.
am i the only one spraying into the head?
freakta care to explain a little???
heres mine i finished up a little after i made this thread. Power: http://i281.photobucket.com/albums/k.../METHsetup.jpg Tank: http://i281.photobucket.com/albums/k...THsetup008.jpg Coming through the trunk: http://i281.photobucket.com/albums/k...THsetup009.jpg Under the hood: http://i281.photobucket.com/albums/k...THsetup004.jpg http://i281.photobucket.com/albums/k...THsetup003.jpg http://i281.photobucket.com/albums/k...THsetup002.jpg http://i281.photobucket.com/albums/k...THsetup007.jpg http://i281.photobucket.com/albums/k...THsetup005.jpg |
i have injectors on the top of the head facing down and other ones facing up
isn't Meth going to mess up sensors if you do pre turbo or supercharger?
^^^^^no
I'd like to here about the benefits of spraying directly into the head.
Originally Posted by freakta
(Post 4012629)
