Your methanol setup
Old May 27, 2009 | 02:59 AM
EXsoccer1921's Avatar
Your methanol setup
alright, i DID search around for this, and only came across info about methanol injection.
what i'm lookin for is, people that have methanol injection. what mix are you running, in combination with what nozzle, where did you put the nozzle. and lastly....why are you running that mix.
Last edited by EXsoccer1921; May 27, 2009 at 02:59 AM. Reason: Automerged Doublepost
Old May 27, 2009 | 03:43 AM
bowtie32's Avatar
Good questions
Old May 27, 2009 | 04:00 AM
Gixxerboy02's Avatar
im running a 50/50 mix (meth/distilled water). I using the 3 gph nozzle and i have it tapped into the piece that connects the intake to the supercharger....Im running a 50/50 mix cause thats what the tuner reccommended...
Old May 27, 2009 | 09:04 AM
383_Stroker's Avatar
50/50 Mix (closer to 70/30 in the winter). 5 gph Nozzle. Injecting into the intake tube.
I'm running the 5gph because I bought a 3, 5, and 7 and desided to start out with the 5... and I'm pleased with the results so I've not changed it.
Old May 27, 2009 | 09:49 AM
Maxim_X's Avatar
Dual 3gph nozzles. I'm running 50meth/50 washer with is like 66% meth.
I am thinking of going with a bigger jet and injecting pre turbo.
Old May 27, 2009 | 02:28 PM
so all of you guys are injecting pre throttle body?
Old May 27, 2009 | 05:24 PM
Maxim_X's Avatar
Yeah
Old May 27, 2009 | 05:26 PM
burnrubr88's Avatar
70/30 mix......which is -20 washer fluid and 4 bottles of heet.
7gph nozzle.
about 4 inches from the TB on the intake.
Old May 27, 2009 | 06:31 PM
is there a reason you guys are spraying before the tb??? i've got a spacer that i was going to use, obviously it'll be after the tb
Old May 27, 2009 | 06:33 PM
burnrubr88's Avatar
Well, lol, im sure the main reason why most of us that are spraying before the TB is because we dont have the spacer.
Doesnt matter though. Works the same way.
Old May 27, 2009 | 07:22 PM
Rodimus_Prime's Avatar
I'm not sure if it applies to these cars but in other makes its better to spray post throttle body because it kills the TPS sensors on some cars.
I'm running 50/50 I get methanol from a place 26 miles north of here for 2.80 a gallon then I get distilled water from the grocery store and mix my own. Far less expensive than using the snow performance or devils own premixed stuff which is 40-50 shipped to your door for only 4 gallons. I go through a gallon a week, which could be in part to the large nozzle, a leak, or evaporation since my tank is not completely sealed due to my filler neck project not being completely finished.
Previously I would have to take out my headlight to fill the tank, pump is in the drivers side fenderwell. So I made this filler neck to make things easier and I also now have a special funnel with a brass fitting on the bottom that screws right on for leak free filling.
I use a Rebel Auto Worx LS4 adapter plate with a 1/8NPT tap and a AEM water injection kit, 550cc nozzle the biggest one with the AEM kit
Old May 27, 2009 | 07:24 PM
hatrickstu's Avatar
5gph nozzle, right before coupler going to blower, 90/10 mix because bryan said so lol
Old May 27, 2009 | 07:40 PM
thats what i was makin sure of hahah. cause i do have the spacer
Old May 27, 2009 | 09:25 PM
bowtie32's Avatar
nice, good thing i got the space too lol, but i did just get the stage 2 meth kit from devils, pretty easy to install your self guys???
Old Jun 17, 2009 | 09:08 AM
devilsown's Avatar
I recommend starting off with a 50/50 mix of methanol and distilled water. We did lots of testing and for most people this will make the best power while keeping things safe with your tune.
Old Jun 17, 2009 | 10:02 AM
freakta's Avatar
i got 4 1gph nozzles and a 50 / 50 mix but i have an extra spot for one more nozzle just in case
Old Jun 17, 2009 | 02:06 PM
i guess i should take pictures of mine now huh
Old Jun 17, 2009 | 04:00 PM
Hockeyman's Avatar
I'm using the ottp spacer between the tb and sc. 3gph nozzle, running a 30/70 mix since I'm only at 20* timing. When the weather is cool I see 11.2afr at redline.
Old Jun 17, 2009 | 04:46 PM
freakta's Avatar
am i the only one spraying into the head?
Old Jun 17, 2009 | 05:27 PM
freakta care to explain a little???
heres mine i finished up a little after i made this thread.
Power:
Tank:
Coming through the trunk:
Under the hood:
Old Jun 17, 2009 | 07:38 PM
freakta's Avatar
i have injectors on the top of the head facing down and other ones facing up
Old Jun 17, 2009 | 08:02 PM
40rty's Avatar
isn't Meth going to mess up sensors if you do pre turbo or supercharger?
Old Jun 17, 2009 | 08:16 PM
freakta's Avatar
^^^^^no
Old Jun 17, 2009 | 08:28 PM
Pickles's Avatar
I'd like to here about the benefits of spraying directly into the head.
Old Jun 17, 2009 | 08:44 PM
what do you mean on top of the head? what are you calling "the head"
