12v Tap in Trunk
Old May 25, 2009 | 12:07 AM
Jplaya023's Avatar
12v Tap in Trunk
I am looking for a 12v source to tap into that is located in the trunk. A few months ago i wired up some interior neons with a 12v source i found in a "How-To" on here. I have some left over bulbs and figured I'd add some more light to our poorly lit trunks. Anyone know where I can tap into to wire 3 12inch bulbs?
bizzump
Old May 25, 2009 | 12:14 AM
Cptn Pants's Avatar
Could tap into the trunk light i guess, but then that'd only be on when the trunk light is... would also wire right to the battery under the rug.
Old May 25, 2009 | 04:52 AM
Nighthawk243's Avatar
The battery is located in the trunk, just use that. Make sure you have a fuse though.
Old May 25, 2009 | 10:30 AM
Jplaya023's Avatar
how would i go about wiring a fuse...i just figured it would be easier to tap into something and wiring a switch rather than wiring it to the battery. The trunk light is a 12v source?
Old May 25, 2009 | 10:35 AM
dabalt4556's Avatar
yea thats how i wired my neons in trunk, just cut the wires going to the trunk light and use themso when you pop the trunk they come on and turn off when you close it.
Old May 25, 2009 | 11:23 AM
Cptn Pants's Avatar
A fuse would be a pretty good idea to be honest...
Battery(+)-----------[fuse]----------{neons}
Battery(-)-------------------------------------'
That little diagram might make it easier, but I'd throw in some kind of switch between the use and the neons (or whatever it is you are putting in there).
Good luck!
Old May 25, 2009 | 10:48 PM
Jplaya023's Avatar
what size fuse would i use? sorry im retarded with fuses and ****
Old May 26, 2009 | 01:12 AM
Cptn Pants's Avatar
Size doesn't really matter too much, the values do. What're you going to be running on there? I use a 5amp 12v fast blow fuse to run all my LED's/Neon tubes and I've never popped one so I'd say you'd be pretty safe with a 5 amp if you are just doing some lighting.
Old May 26, 2009 | 06:03 AM
Jplaya023's Avatar
alright cool...do i have to use any special wire gauge or can i just wire up some small wire right to the battery?
how would i wire in a fuse and a switch? is there a diagram somewhere?
Old May 26, 2009 | 06:06 AM
cobalt123's Avatar
like an inline fuse for amps?
Old May 26, 2009 | 07:16 AM
YelloEye's Avatar
Your current draw is going to be very low with LED bars, same with cold cathode lighting. So regular speaker wire should do you just fine.
Heres your diagram.
BATTERY+ to FUSE to SWITCH to LIGHTING BAR to BATTERY-
Old May 26, 2009 | 10:27 PM
Jplaya023's Avatar
got it all wired up and it came out great...thanks for your help guys!!
Old May 27, 2009 | 12:00 AM
Cptn Pants's Avatar
Take a pic and post
hacadacalopolis
Oct 28, 2015 06:09 PM
goaliemo
Sep 28, 2015 01:37 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
dieGone
Sep 23, 2015 10:20 AM
