19 inch wheels and drop
Hey guys,
I am going to get some 19x7.5 wheels with 225 rubber. These are going on a g5 se model with the 4x100 bolt pattern. Will I need to drop the car after this? If so, how much? Thank you, Adam |
You never "need" to drop a car it just looks so much better dropped then stock. Specialy with rims.
agreed
Originally Posted by Jackalope
(Post 1189483)
I agree. I used to have a tsx on 19's. I had the car lowered 2 inches and it looked hot. Just curious to know if I wanted a similar look. What drop would be needed? Adam |
i have mine dropped on 19s.....it looks a whole lot better with a bigger drop
When you put bigger rims/tires on your car, does it raise up the ride height?
it raises it alittle...depends on your stock rim size
Thank you
Originally Posted by PlaysWitCars
(Post 1189950)
Thanks, Adam |
I have the 5x110.....im using KW coilovers and not too sure how much of a drop it is anymore....but my rear sits right above my tires, same way with the front
http://i86.photobucket.com/albums/k1...verlook011.jpg |
20's
Is it possible to go to 20's without problems?
yeah man.....check out Doc...he has 20s on his and lowered. It looks damn good in person
Originally Posted by blackg5
(Post 1189990)
doc's
Ya his car does look tight. Man I remember back in the day that if you had 17's you were blingin' lol. I have a black g5 se that is a lease with hubcaps. I just want something to make it look a little more slick. Bu tasteful.
Adam |
Bigger diameter wheels does not raise the ride hieght of your car unless you go with larger OUTSIDE diameter tires/ In other words you can make the wheel as big as you want as long as you keep the rolling diameter the same as stock. This will also keep the speedometer working properly.
Your gonna be running low profile tires not super swampers. |
Trying to get to photobucket so I can post a few pics....the .mil i am on is being gay.
My name on there is doc_ss, check out the cobalt ss folder I added a rear strut bar and ever since the outer edge of the tires rub occasionally...It only happens if I take a corner aggressively. |
(Post 1190111)
Originally Posted by OrngBalt
(Post 1190197)
So what your saying is if I take my rims and put a lower profile tire on it... my speedo will be off?
the best way to measure it is this mark a line on your tire and the road, roll the wheel one complete revolution, measure that do the same thing for the new set...compare the distance...usually a 2% difference is acceptable. Now when I upgraded to 20 inch wheels, they are real close the the stock wheels (with tires) so my speedo is really close. |
Ok thanks... I am not changing rim size... I got 16" aftermarkets and was gonna go 45 instead of 55
what size are the stock wheels and tires..?
If your rolling diameter is 28 inches and you go to a 26 inch diameter then yes you will throw it off.
205/55/16 (stock) wanted to go 215/45/16 (new) if i can
(Post 1190245)
(Post 1190245)
112.75 to 96.75 Dimension Tire A: 205/55 R 16 (25 x 8.07 x 16) Width 8.07" (205.00mm) Sidewall height 4.44" (112.75mm) Overall height 24.88" (631.90mm) Circumference 78.16" (1985.17mm) Tire B: 215/45 R 16 (24 x 8.46 x 16) Difference Width 8.46" (215.00mm) Sidewall height 3.81" (96.75mm) Overall height 23.62" (599.90mm) Circumference 74.20" (1884.64mm) Difference Width +0.39" (+10.00mm) Sidewall height -0.63" (-16.00mm) Overall height -1.26" (-32.00mm) Circumference -3.96" (-100.53mm) If your speedometer has been calibrated for 205/55 R 16 (25 x 8.07 x 16) tires, replacing them with 215/45 R 16's (25 x 8.46 x 16's) would result in the speedometer reading high by 5.33%. Same as with the speedometer, if your odometer has been calibrated for 205/55 R 16 (25 x 8.07 x 16) tires, replacing them with 215/45 R 16's (24 x 8.46 x 16's) would result in the odometer reading high by 5.33%. source |
Thanks DOC!
ok.... so we are talking 3 miles an hour at 55 and 5 at 100... no big deal... I thought it was gonna be worse than that.
thanks bro... thats a hell of a website |
remember, that adds a % for every mile you tick off....so, you travel 300 miles and it registers 330.....that adds up quick.
