2.4 coil cover? from sky /sol :D
The DDMWorks Coil Cover will fit both the 2.4 (LE5) and the turbo 2.0 (LNF) motors. This gives you a very attractive and functional piece to add once you remove the plastic engine cover. Whether you have removed your cover for our S/C kit or just to show off your engine a little better, the DDMWorks Coil Cover comes with Stainless steel hardware to attach directly to the Cam/Valve cover. This piece hides the valley between the intake and exhaust cams where the spark plugs and ignition coils set. It will cover up most of the unsightly wires and gives your engine top a very smooth look. Also, by removing the plastic factory engine cover with all the foam insulation, you'll let your engine heat escape better from the top of the head, by allowing airflow over the Cam/Valve cover. The DDMWorks Coil Cover comes standard with a Stainless Steel finish and Stainless Steel hardware,but can be upgraded to one of our in-house powdercoat colors for an additional fee.
i like it it should be able to be used on the 2.4 ions too Very Happy
think this might be what alot of the 2.4 guys are looking for
