9007 vs 9004
there are guide grooves in the light themselves that will prevent them from being installed. these two shouldn't be interchangeable. if im not mistaken, the 9007 has 2 guides and the 9004 only has 1....or the other way around.....something like that
i bought hids and i recieved 9004s they both have 3 grooves and fit in the housing BUT i bought bixenon and dont want the bulbs to be upside down and have highbeams where the lowbeams are and the other way around
The 9004 and 9007 bulbs differ because in the 9004 you have transverse filaments (horizontal) and the 9007 is axial (vertical).....the wiring pinouts are different as well and they should not fit in the same plug because they are keyed diffenently.......i would image you found out that 9004's have higher output on the import bulbs........DO NOT USE THESE.....they will melt your wiring and the housings are designed for the vertical filaments so you will get shitty light from a horizontal filament(9004)...Later
royce777
Sep 28, 2015 07:11 AM
Cobalt-Addiction
Nov 23, 2007 02:26 PM
jasonaudio
55
Oct 16, 2007 09:38 AM
