Adding Foggies to your LS
Old Mar 2, 2006 | 05:00 PM
tallyphotog's Avatar
Question Adding Foggies to your LS
Well, I've got the installation down to the last two steps, and I'd appreciate some help here.
1. I need to wire the switch box into the parking lamps and can't find a place to do that.
2. Whats the best way to bring the cable for the switch through the firewall, hopefully with out cutting a hole.
I've documented the entire process so far, so once I wrap it up I'll be able to post a how to for all my fellow base model drivers out there!
Old Mar 2, 2006 | 11:19 PM
BobWreck's Avatar
Somewhere on the firewall there's a spot where the wiring harness goes through. Always room for a couple more wires there.
Bob
Old Mar 3, 2006 | 02:49 PM
well, getting through the firewall isn't so much an issue as much as it is an incovenience, the real trouble is fiding a way to wire the fog light control switch box into the parking lamps, the little bugger won't work with out it, i guess its a built in safeguard so you don't leave them on to drain the batt.
Help!
Old Mar 4, 2006 | 07:44 AM
Mike's SS's Avatar
Did you seriously call them foggies???? Do you have care bear seat covers or something?
Old Mar 4, 2006 | 10:28 AM
No not really, but thanks for help in sovling my problem.
Old Mar 4, 2006 | 08:21 PM
Mike's SS's Avatar
I think that either here or r e d l i n e f o r u m s . c o m should have a wiring diagram if you do a search.
Old Mar 4, 2006 | 08:39 PM
Cobalt_Supercharged's Avatar
I guess that's one way to prevent the site name from being edited.
If you could find a wiring diagra that would show you which wire it was you could tap into it. WopOnTour could probably help, if I'm not mistaken he is a GM Shop Tech.
Old Mar 5, 2006 | 09:52 AM
Excellent, thanks for the nod in the right direction. I'll be building a tutorial once I get it right.
Tykuura
Nov 3, 2015 08:58 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
allpro666
Sep 24, 2015 04:42 PM
dieGone
Sep 23, 2015 10:20 AM
