Additional courtesy lights
Old Jul 24, 2006 | 11:51 AM
KeystoneSC's Avatar
Question Additional courtesy lights
Has anyone else wired additional courtesy lights to come on/go off when you open/close your door? Where did you make your connections?
I'm considering flush mount courtesy lights on the door sill, I'm just curious if anyone else has done this yet.
Old Jul 24, 2006 | 06:02 PM
KeystoneSC's Avatar
bump.
Two thoughts tried were 1) connecting to the plunger on the door frame and 2) connecting to one of the wires leading to the map lights on the mirror. Neither idea worked.
Any other suggestions?
Old Jul 24, 2006 | 06:11 PM
HackAbuse's Avatar
Did you evaluate how the plunger on the door works?
If it uses the basic concept of short circuiting a certain voltage, you could wire a relay up to it, so that when the circuit is completed, it would trigger the relay to power anything you want.
HackAbuse's Avatar
Old Jul 24, 2006 | 06:27 PM
KeystoneSC's Avatar
That's what I'm going to have to wind up doing. I was hoping for a direct feed, but the circuitry won't work that way. No biggie.
Thanks for the input.
Old Jul 24, 2006 | 06:29 PM
HackAbuse's Avatar
Let me know your results, it would be neat if my underglow would turn on when a door was opened
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
