Any body willing to do a how to on........
didnt see that when i looked ill get on that hahaha
all you have to do is run a wire from the green/yellow(depending on which side of the car your on) wire to the power wire for the LEDs but here is the hard part. You first need to go get two diodes and a 20k om resistor. when you first come off the brown wire put the resistor and then the diode and then come off the green/yellow wire with a diode and hook the two diodes together and then hook them up to the power wire on the LEDs. that will make them blink and light up with the turn signals and brakes
