Anyone ever had HIDs do this?
Old Mar 11, 2009 | 11:19 PM
RedEcotecSS's Avatar
Got my HIDs from 3bspec today. Installed them according to the how-to on the forum. When i turn them on my passenger side only worked. I look at all my wiring and could not figure it out. So i decided to swap ballast sides. Then the driver's side came on fine. Then swapped sides with the bulbs. Passenger side (ballast that never turned on) didn't come on at all with the good bulb in it. Driver's side (ballast that works) would only make the HID bulb flicker once, then turn off. Very strange.. Called 3b and they are sending me a new ballast and bulb. Very nice vendor just wondering if anyone else had a similar issue?
Old Mar 12, 2009 | 12:36 AM
Ferretts's Avatar
Try changing your fuses to 20s... Get the new ballasts and bulbs too, but change the fuses anyway
Old Mar 12, 2009 | 01:14 AM
Doesn't seem like a fuse issue. But I will try anyway. I'm thinking its the ballasts and or bulb.
Old Mar 12, 2009 | 01:17 AM
1badBlueberrySC's Avatar
it's due to the extra load on the wiring... that is why you need the extra relay!
You just have to turn off the lights and turn them back on that is what I had to do with mine on the old car... haven't hooked them back up yet!
Old Mar 12, 2009 | 01:21 AM
hossdeuce's Avatar
swap fuses for 20's and accept the new ballast/bulb
if the problem keeps happening, maybe completely disconnect everything and start from instruction 1 again
Old Mar 12, 2009 | 01:23 AM
XxDHiLLxX's Avatar
what fuses? and where? mine or doing the same
Old Mar 12, 2009 | 01:30 AM
They are talking about the inline fuse going to your positive. If it was the fuse when why will one ballast always come on but the other won't? Kinda strange but ill mess with it again tomorrow a little. What would determine if I absolutely needed a new bulb?
Pretty sure that one bulb is bad. One will turn on fine but when I switch bulb sides one of them won't work on either.
Last edited by RedEcotecSS; Mar 12, 2009 at 01:30 AM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 08:04 AM
TRANSAM197781's Avatar
did you happen to touch the bulb with you hand if so the grease from youre hands can ruin it when you fire it up
Old Mar 12, 2009 | 08:23 AM
nope. i was very careful not to touch it.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
juandirtymessican
Oct 27, 2012 10:41 PM
