Anyone try these?
Anyone try these?
Was thinking about switchbacks but I dunno if I like the ones that show all the little led lights.
Has anyone tried or have seen them on a car?
3157 3457 4157 High Power Switchback LED Turn Signal Light Bulbs
Thanks
T
Thanks
T
The only problem with those is that they appear to be only forward firing. So the reflector won't be reflecting any light and the housing won't fill up. I have the other switchbacks and i love them. I get compliments all the time
I have a set of these in my car I a think they are totally worth it.
When I ordered them I bought the load resistors they recommended, because you will need to use them to fix the hyper flash.
I tried without installing the load resistors and you will get hyper flash IMO is really annoying.
To wire them up I soldered the load resistors between the blue and black wires going to the blinker. You are going to need a load resistor for each LED bulb.
I got mine from from here3157 3457 4157 High Power Switchback LED Turn Signal Light Bulbs
They plug right in the blinker socket.
