Automatic Shift Knob
Old May 28, 2008 | 01:38 PM
CCBalla10's Avatar
I have searched and a lot of ppl. were wanting to know if it can be done. All the threads were really old so I was wondering if anyone had figured out if it can be done. Any pics?
Old May 28, 2008 | 01:43 PM
OrngBalt's Avatar
there is no question... can what be done?
Old May 28, 2008 | 01:46 PM
CCBalla10's Avatar
if you can change the knob
Old May 28, 2008 | 01:49 PM
OrngBalt's Avatar
I donno if anyone has done it, but it can be done. Just find one that fits. Taking it off is the hardest part.
Old May 28, 2008 | 01:54 PM
CCBalla10's Avatar
haha already got it off
it was actually pretty easy, put in drive with car off, twist chrome piece counterclockwise 3/4 of a turn and pull down....then you will see the screw. use an allen wrench to loosen and pull knob off
Old May 28, 2008 | 02:00 PM
OrngBalt's Avatar
yea, its a piece of cake.... I just dont know if there are replacements available. Other than OEM pieces. I am sure you could find one somewhere tho. I wanted to take mine off to paint it.
Old May 28, 2008 | 02:03 PM
CCBalla10's Avatar
well i got to thinking...what happens inside of the shifter when you push the button in is a shaft is pushed straight down the shifter pushing another shaft down to unlock it. So my question is, are their any knobs that when you push the button it pushes down a shaft? I could always make the shaft on the inside as long as i want on an aftermarket to make it work. Just didn't know if anyone had really looked into it
Old May 28, 2008 | 02:05 PM
mrsilent13's Avatar
ive looked into it...all you need to do is find and auto shift knob....should fit fine....good luck.....
Old May 28, 2008 | 02:07 PM
hinow41's Avatar
I didn't replace mine but i did paint it. Real easy to do Just take off the silver plastic ans sand it a little and then paint it what ever color you want
Old May 28, 2008 | 02:11 PM
CCBalla10's Avatar
do you have one in your car?
OrngBalt's Avatar
how is it held on? is it double sided tape?
RaginChopsuey
Oct 27, 2015 01:27 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
