Best way to remove scratch
So i was lookin at my car today admiring it when i noticed 3 or 4 huge scrapes on the my bumber right in front of my passenger tire. There was a white chalky dusting on them like it was from rocks or something. I have no idea how it got there. Anyways most of them arent that bad but the one is. I used rubbing compound to kinda clean the scratches out then i used come wax. They are better but it still killin me Any suggestions?
You can't necessarily REMOVE a scratch. You shave the clear coat down around the scratch just fractions of a MM. Use ScratchX from Meguire's. It is an abrasive that very gently sands down your clear coat, reducing the depth of the scratch. Then use a clay bar to pull off excess particles, then wash n wax.
GM makes a "Cleaner Wax" that we use at the shop. That works great if you don't want to go nuts, but other than that you can try to use a buffer with some compound. If its through the paint than the only thing to fix it would be filler and paint.
Clay bar is a very effective way to clean any sort of dirt/contamination/whatever out of your paint. Just go to like, advance or autozone, and they sell a clay bar kit. Mothers is the brand name.
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
