complete color change
Old Mar 26, 2015 | 10:30 PM
FasterThanDocHoliday's Avatar
hi,
i'm looking foward to respray my white cobalt sedan. i would paint the hood, roof, trunk and maybe door handles, drum brake/caliper orange (with clear coat) the rest of the car would be matte black. i never painted a car myself before. any tips on how to do this ?
Old Mar 27, 2015 | 06:56 AM
Wert842's Avatar
Please no...
Old Mar 27, 2015 | 07:11 AM
turboecotec02's Avatar
Walmart sells cans of paint for a dollar I believe. Post up pics after your done
Old Mar 27, 2015 | 07:59 AM
Clear out your entire garage if you have one. If not, youre already screwed. Install a heater, air conditioner, air cleaner and dehumidifier. You need perfect constant temps, humidity levels and dust control. This will not work if your garage is 85 during the day, 45 at night and dusty. Unless you like having shitty paint that is
Get a sandblaster and all sorts of paint stripping tools
Strip every bit of paint off the car down to bare metal and clean accordingly. For a measure of how long this could take, it took a friend and i a combined 30+ hours to strip his empty engine bay to paint. And we could sandblast the hell out of it, scuff, wire wheels, wire brushes, sand paper, razor blades, vaccuming, air blowing, acetone/aircraft paint stripper, you name it.
Cant stress enough how important prepping and cleaning is. Any spot where you left existing paint or primer will show a level higher in the final product.
This is an oppurtune time to fix any existing damage. Why go throygh all this if you dont?
Also an oppurtune time to do any other body modification as well. Id just get brand new unpainted bumpers and sideskirts and spoilers because theres really no way of stripping the paint off of them without destroying the plastic far as im aware. New mirror caps as well.
By now you will find that your whole car is apart might as well drop your subframe/engine and do the bay. You gotta take the doors off and strip the inside of those and the door jams on the car side.
Mask every thing off perfectly. Do not skip any part of this, you need a perfectly clean car. Keep the floor perfectly clean.
Mask a surrounding area around the car 5 ft and any direction with plastic sheets. No airholes allowed except from air cleaner/heatig/cooling ventilation.
Buy a facemask and painting suit unless you wanna paint your skin, lungs and eyes.
Buy a paintgun unless you dont want to paint your car
Buy a large (200+gal) air compressor unless you dont want to paint your car
Buy paint. High quality primer, color coat and clearcoat. Will take a few gallons of each and should cost a few hundred bucks.
Wet the floor and keep it wet throughout the process. This will capture any dust. Also another reason that humidity control is very important.
Paint the car. 70ish degrees throughout process, prime it even strokes from front to back overlapping strokes by half from top to bottom. Let dry and do again.
Then paint in similar fashion add more coats for more pop
Then clear. The more the better and the more you can polish and the deeper it will look.
Let cure for atleast a week.
Then wetsand whole car, rinse, and polish to a perfect shine
Congrats, you just painted your car in your dreams!
Old Mar 27, 2015 | 08:25 AM
Sl0wbaltSS's Avatar
Originally Posted by Wert842
Please no...
2 char
Old Mar 27, 2015 | 10:12 AM
Thanks for all the jokes. But seriously i want to repaint it because the previous owner had the car rammed in and now i have a door and a fender taken from a dark blue g5. My car looks already bad the way it is now, so i better try to completely respray it instead of just painting those two panels. And besides i hate the white color
Old Mar 27, 2015 | 11:08 AM
blueLNFftw's Avatar
You are better off doing a $300 Macco job than painting it yourself if you are asking how to paint it...
Old Mar 27, 2015 | 11:17 AM
tuned08ss's Avatar
This x1000
Old Mar 27, 2015 | 11:57 AM
double clutch's Avatar
You should just get those 2 panels resprayed professionally. If its your first time painting then your not gonna be happy with how it comes out. Ive had my project car in the prep process for almost a year and ive still got a lot more to do. Its a very long and tedious process and any cut corners will be easily noticeable.
Old Mar 27, 2015 | 02:44 PM
No joke from me man but my reply said you are definately much better off getting it done. I would never spray my car if it was my first time spraying,
Old Mar 27, 2015 | 02:54 PM
Please no...
X3 i wouldnt paint it another color. But since your set for it just take it to a professional and have them paint it unless you have everything to do the job correctly
Old Mar 27, 2015 | 07:59 PM
crispino's Avatar
Riceburner is pretty dead on realistically.. but I used to work in a body shop, you can paint the over clear coat if it's scuffed up, meaning DA the whole car, every inch in 320 grit until it's all the same color (different colors are different paint heights) and then paint and clear.. only real issue with doing this, is that the color you pick will be different because of the back ground color, and that doesn't mean put 20 coats of paint to bury it.. hope that helps, everything else he said was 100% accurate and the real and honest way to do it, but my old orange cobalt had ss body panels and number from blue car and I used a deep red as a base coat to hide the Blue and then painted my top coat (orange) and even up close the paint was hard to tell apart from factory paint for the trained eye let alone some shuck lol but good luck brotha
Old Mar 27, 2015 | 08:07 PM
Superbolt's Avatar
One of the guys here in town painted his cobalt ss with plasti dip spray cans and it didn't turn out so bad ..plus side you can peel it off. Lol.
Old Mar 27, 2015 | 09:07 PM
what if i sand it to bare metal completely ?
Old Mar 27, 2015 | 09:09 PM
Superbolt's Avatar
Lol you will be doing even more work then.
Old Mar 27, 2015 | 09:45 PM
$1.00 walmart spray paint FTW
Old Mar 27, 2015 | 09:53 PM
Old Mar 28, 2015 | 12:24 AM
swanman35's Avatar
If you wanna cover up different panels I'd just do plastI dip. It looks decent and it will probably last longer than a bad paint job would.
Old Mar 28, 2015 | 09:53 AM
sLAsh's Avatar
Wrap the panels you want to change
Old Mar 28, 2015 | 10:21 AM
Id also just opt for plastidip honestly, go on craigslist or something there's people that will dip your car for 500 bucks any color ya want and there clearcoat for.it too just gotta be careful with bumping stuff into it for longevity reasons and its a little different to wash.
Old Mar 28, 2015 | 11:10 AM
breds2k's Avatar
PLASTIDIP!!! After seeing a new color shift pearl with the DYC high gloss top coat, I was AMAZED at the difference in finish from what original plastidip looks like. Im going to do my HHR in something wild this summer.
Old Mar 28, 2015 | 01:06 PM
swanman35's Avatar
I LOVE the matte white plastidip look. Looks so clean
Old Mar 28, 2015 | 01:16 PM
I wanna plasti dip my car maybe like that i can win Fcotm lol
Old Mar 28, 2015 | 03:47 PM
Old Mar 28, 2015 | 03:52 PM
Superbolt's Avatar
Originally Posted by double clutch
That car is nice I wish my car was white
