Could someone give me information on the shift knob?
Old Jul 2, 2008 | 12:56 PM
Vexiss's Avatar
I can never manage to get the darn thing off. If someone could tell me how that would be a big help. Also, it would be great if someone could give me the following information about the knob (although I could surely do it myself if I managed to get it off): the thread size and length of it, and the diameter of the recessed area on the actual knob, and the depth of the area. Thank you.
Old Jul 2, 2008 | 02:00 PM
Whitty's Avatar
search / check out the how to section im 100% sure it has to be in there
Old Jul 2, 2008 | 02:02 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Pop off the part that has the numbers on it with a tiny screwdriver.
Old Jul 2, 2008 | 02:05 PM
Whitty's Avatar
he may have an ls / lt which wouldn't have that plastic thing... i know mine doesnt
Old Jul 2, 2008 | 02:07 PM
alleycat58's Avatar
Yes, you need to tell us which model.
The SS/SC & SS/TC shifter is not threaded, it's pressed on (and spring loaded, so don't get your face in front of it while taking it off).
Old Jul 2, 2008 | 02:29 PM
CASol's Avatar
if its an auto you twist the chrome plastic about a 1/2 turn then pull down, then you need a torx to remove the screw, then pulss off.
reinstall in reverse order
Old Jul 2, 2008 | 02:46 PM
Vexiss's Avatar
It's an SS/SC.
Old Jul 2, 2008 | 03:29 PM
alleycat58's Avatar
Then pull like hell. First try prying off the little plastic piece with the shift pattern on it, some people have had a screw or something under there? Mine did not. I had to take it out and pry like hell to get the knob off and it's not threaded on at all. So if you're planning on just slipping an aftermarket shift knob on, you might have an issue.
Old Jul 2, 2008 | 03:45 PM
blue06's Avatar
When I had the stock shifter on my SS, I took the stock knob off by taping the bottom of the knob with a rubber mallet and it eventually popped off. I had the same problem, I even gave up and took the aftermarket knob back to the auto store. Your better off just changing the whole shifter with a Hurst like I did, Hurst makes a real nice shifter
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
