Cruise control LED
will do, but a warning, I "tweaked" my led because I couldn't find a blue small enough. It is actually quite quick and IMO easy. When I find the camera I will tear it back apart to do the how to correctly. I hate the how to's without pics. Probably by Saturday.
Exactly what I was thinking before adjustability ran through my mind. To dull the orange, i originally used a small piece of plastic, I believe it was from a fast food drink lid. I thank I will use a blue sharpie
oddly enough, when I was hooking up my gauges, i tried to just "tap" the wires (each of them) that come out the back of the dimmer switch for the dash lights and apparently that thing is not a POT that just changes the voltage... from what I can tell it's actually some sort of a "sensor" that is read by a "computer" that dims the lights. If you'll notice, at least on my Ion anyway, when you roll that dial, the dimming doesn't happen "instantly" or "inline" w/ you rolling it (as it would w/ a straight-up POT), it's a bit delayed and "fades" in or out as you roll the dial.
Really kinda pissed me off.
There was a "how-to" in one of the Corvette mags about doing this same thing to the window / door locks in the door panels, adding the LED in there.
THey say the same thing about using a dremel to grind it down to fit.
Anyone think about trying this approach to the dash cluster lighting???
