Debadge Help
Gonna need to take some more serious polish to it.
Also, try cleaning with acetone first, it will remove all the wax but should dissolve any crud left on the paint that was under the badges. Then use a slightly more aggressive polish to clean up any swirls or scratches or unevenness, then wax as normal.
That's after goo gone. Literally using my whole weight to really scrub it, used my finger nails. Nothing..it just doesn't budge.
I'll try more goo gone tonight. Then I'll re wax and polish and attempt to get it out.
If you're willing to learn and take your time and invest a little in the right tools/chemicals there's a ton of info on the web about removing oxidation from paint, look at what some of the others have done and see what you feel most comfortable with and give it a shot.
If you already used a solvent like Goo Gone, then it's oxidation in the paint/clear like Chris said. You need to remove that top layer with a compound/polishing step then wax it back after. If you aren't familiar with the process, it might be worth finding a local detail guy to buff it out as on a black car you can do a lot of damage to the paint that will really make it look like **** if you don't know what you are doing.
