Debadging Efficiently
Old May 13, 2011 | 04:15 PM
{LZ}CobaltSS's Avatar
Okay so i want to remove the Chevy Emblem, and the Cobalt lettering from my car. Most efficient, safe way with a Hairdryer on a hott day, and without removing the clearcoat/paint on my car?
Old May 13, 2011 | 04:16 PM
BPacak's Avatar
Vtec Rep
dear god. fishing line. goo gone. done.
Old May 13, 2011 | 04:17 PM
TommyP's Avatar
AWD > FWD
or if you don't have strong enough fishing line, a plastic kitchen spatula will work.
Old May 13, 2011 | 04:27 PM
brainchasm's Avatar
Whatever you do (or especially if you do this) make sure that if you're prying up one end, that the OTHER side isn't digging into your clearcoat.
*grumble stoopid GM square, grah*
Old May 13, 2011 | 04:33 PM
TommyP's Avatar
AWD > FWD
troof, gotta be careful with that.
Old May 13, 2011 | 04:35 PM
AndrewSS/TC's Avatar
Be different, and leave your badging on LOL
Old May 13, 2011 | 04:38 PM
startingline05's Avatar
best way is using a grinder wheel. it will work like a charm
Old May 13, 2011 | 05:00 PM
livingdeadpk's Avatar
yep thats what i did
Old May 13, 2011 | 05:52 PM
Hammbones's Avatar
Make sure you wash it with Acid
On a serious note, I used no chemicals at all. Plastic Spatula, Clay Bar with soap water until its all gone =) Of course I peeled as much of the adhesive off by hand before I tried to clay bar it =)
Old May 13, 2011 | 05:57 PM
N1ckateen's Avatar
i've used dental floss even lol. then pealed the glue off by hand then washed then used a buffing compound and it looks perfect.
Old May 13, 2011 | 06:58 PM
tunameltman's Avatar
Its getting time for me to debadge mine hopefully there aren't clearcoat problems under them. I was getting ready to rip my wing off and noticed a little clearcoat issue around the base of the wing. Roof already looks pretty rough. Plan on reclearing the whole roof soon, and I guess where the wing is too, lol.
Old May 13, 2011 | 07:19 PM
DiabeticKripple's Avatar
all my black stuff was left on the car, and i was gonna rebadge it on the back, what should i use to stick it on good?
Old May 13, 2011 | 09:34 PM
Hammbones's Avatar
3M Double Sided Tape
Old May 13, 2011 | 09:37 PM
carstedt's Avatar
heat it up..[peel it off then use the "Eraser" piece type deal that goes on the end of a drill to take out the outline and shine it up...thats how i did mine
Old May 13, 2011 | 09:38 PM
bigrroberto's Avatar
2x on the fishing line.
Use a hair dryer and warm it up, then gently pull the fishing line across the back of the emblem. Very slowly move it back and forth as if your flossing your teeth and it will not scratch at all. Patience is key. Then after use a microfiber cloth with goo-gone to remove whats left. dab with the cloth don't rub. Then wash with soap and water. Wax and done.
Old May 14, 2011 | 05:51 PM
smallkiller's Avatar
I fucked up the GM squares..... Never had so much regret in my entire life
Old May 14, 2011 | 06:01 PM
Refractor's Avatar
I used dental floss, the florida sun, water and my fingernail.
Old May 14, 2011 | 08:40 PM
H3 Proto's Avatar
You don't need strong fishing line. I used 6 lb. If it's not working, you're doing it wrong.
Extreme Dimensions
Sep 24, 2015 07:51 PM
dieGone
Sep 23, 2015 10:20 AM
toledobalt
Sep 2, 2015 07:04 AM
wesmanw02
Feb 9, 2006 08:58 PM
Brian MP5T
Forced Induction
Nov 14, 2005 09:46 PM
