did i mess up my front window???
my tint was peeling off the front window so i went ahead and ripped all the tint off and now there is a sticky residue on the window preventing me from rolling down that window properly.... the next da i can get it retinted is friday and i am wondering is the sticky residue gonna sumwhat glue my window to the seal???
Originally Posted by Yahoo
Here is what to do. look up this product SD20. its a degreaser that car tinters have been using for a long time to remove the adhesive on tint they are removing. It can be found at home depot in my area but you may also be able to get it online. stronger than goo gone. the big difference is that it sprays into a light foam (cover your mouth, smells and tastes like its bad for you to inhale). what you do is spray this on the parts of the window that have the glue still on them and just let it sit for 10 minutes while the glue dissolves. then use a single edge razor (stainless steel and brand new... anything else can and will scratch your glass) and lightly drag down the window and be amazed how quickly the stuff comes off. it will leave a little degreaser residue so after its all off just use a damp cloth and wipe the rest of the degreaser. hope that helps
http://answers.yahoo.com/question/in...9125541AAjoOuv
just search "how to tint removal" in yahoo....
windex and a razor blade dude....takes 5 min
wet down the window with windex covering the whole surface
use the razor blade at no more than a 45 degree angle to the glass and just work ur way around the window until you get all the glue off
wipe it down
repeat as neccessary for any spots you miss
i do this all the time at work cuz we have to take the tints off any cars traded in
wipe it down
trust me im a pro at this i do at least 5 cars a month like this...my way works and its using **** u have laying around the house and you can do it asap u dont have to buy anything specific
maybe also mention that with using a straight razor balde...the corners of the blade will scratch the **** out of the window if your not careful !!!!!! if you have never done this before be ******* carfeul.even tinting over scratches you wwill see them throught the tint.
you might also try to get nylon razorblades, or plastic ones or even a plastic putty knife. maybe heating glass witha a ahirdryer and steelwool.
be careful...
my 2 cents
be careful...
my 2 cents
be careful...
my 2 cents
be careful...
my 2 cents
thats why i said keep it at less than a 45 degree angle to the glass...very unlikely thta it will scratch...and you dont need to use a lot of pressure just glide it over the WET glass and the glue will come right up ....just make sure you keep the glass wet with the windex
i thinkn you left some key parts outta that phrase lol...corners of razor blades will kill glass whatever angle you use it on.
best thing you can do with razor blades is take them to a benchgrinder and round of the corners slightly.then you wont have to worry about diggin into anything.
im not hating on you bro.i just think more needed to be said about it.
n20saturn
09-30-2015 12:26 AM
