door molding/removal?
Old May 18, 2010 | 11:57 PM
scottie's Avatar
I've got door moldings down the side of my car. Was wondering if these were taped on or clipped on. The paint is really starting to fade on them and looks like ****. I'd take them off but I don't want to get stuck with the holes for the clips or whatever else might fasten them on.
Anyone do this?
Old May 18, 2010 | 11:59 PM
07cobalt2.2's Avatar
its just like all the other emblems, pain in the ass though, but its worth it. so yes, it is just paint under there
Old May 19, 2010 | 12:08 AM
scottie's Avatar
No holes I'll have to fill in? I've removed all the other emblems. It was a pain but I did it fine. I just don't want to fill any holes in that might be there if they were tacked on or something. Never did any moldings before. But the paint is toast on them. looks like ****
Old May 19, 2010 | 12:19 AM
its just like removing any other emblem but it takes alot longer lol but nope no holes looks great when done.
Old May 19, 2010 | 12:21 AM
scottie's Avatar
thanks a lot man.
Old May 19, 2010 | 12:28 AM
heathkidder's Avatar
make sure to use fishing line all the way down the side molding dont stop once u got it alil off and pull it off the rest of the way to much adhesive gets left on the car that way and involves alot more work
Old May 19, 2010 | 12:32 AM
this^ this is why I say its such a pain cause I was in a rush and just ripped it off. take your time lol
Old May 19, 2010 | 12:44 AM
one door took me an hour then other door took me about ten min. lol so take your time with the string dont just rip it off
Old May 19, 2010 | 07:23 AM
scottie's Avatar
Yeah thats how I did everything on my tailgate. Still was a pain in the ass to remove all the left over adhesive. But at least I know what I'm getting myself into now.
Old May 19, 2010 | 01:01 PM
SlobatLT's Avatar
easiest thing ever....you know how you hold dental floss? a little bit wrapped around each of your index fingers? Get some string..about the size you would use to fly a kite...and put it around your fingers like that...then get on the side of the molding and put that string in the tiny amount of space between the molding and door (against the double sided tape thats holding the molding on) and move the string up and down....the friction from the string will cut through that sticky ass tape like a razor blade. it took me maybe 3 sec. to get em off.
Old May 19, 2010 | 05:47 PM
scottie's Avatar
wouldn't that be basically the same thing as fishing line? I did that with the emblems on the back. But wrapped them around to pencils and held them instead. but it down down the middle of the 3M so I had to rub everything off still.
Old May 19, 2010 | 05:55 PM
TommyP's Avatar
AWD > FWD
This is going to be really easy if it's 75+ degrees outside. Just some string and your good to go. I would suggest a plastic spatula like this
instead though as I kept breaking 20lbs fishing string.
Old May 19, 2010 | 06:06 PM
scottie's Avatar
yeah I would have killed for one of those with my chevy emblem. I'll pick one up from work before I get at it.
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
satisfied
Oct 19, 2015 12:35 AM
dasoftest
Sep 29, 2015 02:14 PM
xxenjoi11
Sep 29, 2015 12:36 PM
dieGone
Sep 23, 2015 10:20 AM
