Easy Lifting Vertical Doors???
Does any one know where to find verical doors that are easy lifting, gf doesnt want to lift heavy doors
Ppl said cobalt addition verical door kit makes the doors heavy to lift so can anyone help me out
I've searched and cant find anything
vertical doors (the company) makes a great kit...for most door applications thru out all companies the shock should be strong enough to lift the door all u have to do is provide the momentum...
Yea momentums the problem girlfriend wants to make sure the shock does most the lifting. She doesnt want to lift up a heavy door getting in and out of the car.
high maintenance much? jk but yeah honestly if it lifts it up automatically, then she has to pull it down to get into the car... its not gonna be no effort both ways
for momentum i ment opening it...on the kits i have personally experianced (i live right by vertical doors, gt factory, and jt autobody) they all push themselves up when the door is opened to its certain point before it goes vertical...no door lifting was needed
I was just wondering cause i ask a person and they got doors from cobalt addicition and he said he hated how heavy the doors are to lift and pull down
Some companies you can pay extra and the come with different options for the kits. I have seen vertical doors with an electric motor to open and close them all you do is hit a button. You might be able to get that for your kit.
Just make sure they come with heavy duty shocks. and I have the JT kit and the 150lbs shocks arn't good enough. there are some kits that have a dual shock set up that is 300lb per door this should be enough.
damn 150lb.....thats crappy..haha...Vertical Door's gives you really good shocks now with the kits. Before they were just strong enough but now they have even better ones
