engine bay clean up and something else?
Old Jun 22, 2012 | 04:28 PM
klutch814's Avatar
Alright i need some help guys. I'm a turbo 2.2 and my engine bay looks like ass. i wanna get it all clean for shows and such. i need help hiding wires somewhat and how to get this **** clean. i also have access to a power ball and polish for the drill. some pics:
also i need to find a better way to put my xm antenna its a magnet..
Old Jun 22, 2012 | 05:04 PM
Crav3's Avatar
I'm a noob on turbos but I always never know what the pipes are going to and coming from lol
Old Jun 22, 2012 | 05:15 PM
chitala383's Avatar
I put my Sirius antenna behind the shark fin type one. It fits there perfectly and looks great
Old Jun 22, 2012 | 05:35 PM
C_A_D88's Avatar
I have a gps antenna like that one, hid it under the rear deck liner, works mints
Old Jun 22, 2012 | 11:21 PM
klutch814's Avatar
ill have to put it there
Old Jun 23, 2012 | 02:57 AM
TommyP's Avatar
AWD > FWD
really the only way you can do a wire tuck on these cars, is to unplug everything, group as much of it together as you can, and zip tie it in one big bunch. You cannot add wire like a lot of wire tuckers do because the bcm/ecu runs on voltage signals and adding/removing wire changes the resistance in the wire.
Also, good way to clean up those black wires/hoses, is tire shine. Works great.
Old Jun 23, 2012 | 02:59 AM
CannonBalt's Avatar
I have my Sirius/XM antenna under the dash in the front. Works good unless you go under a bridge.
Old Jun 23, 2012 | 08:16 AM
klutch814's Avatar
i didnt necisarly ment a full out wire tuck.. just group them?? also theres like a gritty dirt on my block/trans any suggestions
Old Jun 23, 2012 | 08:42 AM
Mindrot's Avatar
I will take photos today and try to show you what I did. As stated before wiretucks are difficult on this car. I used braided lining (wraps around like a sleeve) for most of the electrical harness. Also consider powdercoating a spare fuel rail. Would bring less attention to the "stocker" looking things in your bay. Tireshine is also your best friend!
Old Jun 23, 2012 | 01:46 PM
Cobalt08LS's Avatar
you could take that blue wire. and put it under the charge pipe and around the back of the valve cover to get it mainly outta the way
like this
quick paint mock up
than the wires by your driver headlight you can try to feed into the current loome to hide them and can wrap electrical tape around so you dont notice the red that much
and did your car not come with XM from the factory? or did you remove it from the roof and weld up and paint the hole up?
Old Jun 23, 2012 | 04:11 PM
klutch814's Avatar
didnt come with xm.. and blue is the vac lline for the BOV.. pics of this braided **** i wanna see lol
Old Jun 23, 2012 | 06:42 PM
Mindrot's Avatar
Old Jun 23, 2012 | 06:58 PM
Cobalt08LS's Avatar
Originally Posted by Mindrot
This stuff kooks legit!
Try moving it like i suggested?
Last edited by Cobalt08LS; Jun 23, 2012 at 06:58 PM. Reason: Automerged Doublepost
Old Jun 23, 2012 | 07:39 PM
klutch814's Avatar
Where do you get that stuff from
Old Jun 23, 2012 | 07:40 PM
Mindrot's Avatar
It can get pricy depending on how much you get. Typically $2-$3 per foot depending on size of diameter. Website is cableorganizer.com. Good up to 450*.
Old Jun 23, 2012 | 08:12 PM
klutch814's Avatar
Can you tell me hoe much of what sizes you used
Old Jun 23, 2012 | 09:41 PM
06_cobalt's Avatar
Mindrot that looks really good.
And to clean the sides of the motor from grease and stuff you can use simple green, brake cleaner, all kinds of stuff. But I use simple green. Get your motor up to operating temp then shut it off and spray on the simple green. If it's bad enough just a little scrubbin will get in looking good.
Old Jun 23, 2012 | 11:00 PM
Mindrot's Avatar
I used the 1/2" and 3/8" the most. I have a lot of the smaller ones that I didn't use.
Old Jun 23, 2012 | 11:05 PM
Mindrot's Avatar
I'm not too certain about the sizes. Its the two largest ones they offer for this specific braiding.
Old Jun 24, 2012 | 12:38 AM
klutch814's Avatar
this?
Expandable Braided PET Sleeving in Black
Old Jun 24, 2012 | 08:54 AM
Mindrot's Avatar
That's not it. Its a wrap around sleeve. I'm on the road right now heading from Chicago. If you can't find it then I will look it up tonight.
Old Jun 24, 2012 | 10:38 AM
klutch814's Avatar
yea link me when you get back man
Old Jun 24, 2012 | 11:14 AM
PsychoCam's Avatar
Just take ur time and start re routing wires and tryin ur best to hind as much as you can. Use tire shine/armor all to clean it all up. Use some simple green or any kind of degreasor if u need/ want to clean the motor up. Use tooth brushes and small rags. Takes time but u can clean the bay up pretty good
Old Jun 24, 2012 | 08:38 PM
Mindrot's Avatar
Old Jun 24, 2012 | 08:39 PM
Mindrot's Avatar
F6 Braided Wrap-Around Sleeving
