Exploding Headlights!?
Old Sep 23, 2008 | 04:39 PM
biniecki's Avatar
I got out of my car today after getting home from work and noticed something strange about the driverside headlight. Inside the headlamp at first looked to be drops of water but at closer inspection looks like shards of glass or plastic. I gave the headlamp a once over to make sure no one had damaged the headlamp itself and began wondering where in the hell did these shards come from. I then decided to turn the headlights on to see if they were working. Turns out the driverside bulb was out. It looks like it quite literally exploded. Has this happened to anyone else? Any suggestions on which replacement bulbs to go with?
Old Sep 23, 2008 | 04:43 PM
NCC-2000's Avatar
The light bulb blew up? Damn, I'd like to know how it managed to do that.
Old Sep 23, 2008 | 04:57 PM
alleycat58's Avatar
Probably condensation or a water leak. Bulbs blowing up isn't THAT uncommon, but still a little odd when it does happen.
Old Sep 23, 2008 | 05:22 PM
silver187666's Avatar
check some fuses man, i had a lightbulb blow out on my old car, was cranking to much wattage to it,
Old Sep 23, 2008 | 05:29 PM
tombomb's Avatar
ninja catz? do you live near ninja catz?
but all seriousness silver187666 is right, faulty fuse can do that
Old Sep 23, 2008 | 05:33 PM
originaladrian's Avatar
that could happen, esp if u got something on the light bulb itself when installing like oil from ur hands.
Old Sep 23, 2008 | 05:34 PM
GTO 1's Avatar
Had that happen to a 2002 Impala. Left front did the same thing. In this case is was a police car and was upfitted with corner strobes in the front parking light section. (We cannot install strobes in the headlight portion). Car was parked with headlamps and strobe bulb working a while. In my case, must have been the excessive heat (air temp) in the headlamp capsule. It was a vilent explosion, to the point of having to repace the entire headlamp capsule! I haven't used both lights at the same time for any long period of time since then. I have never had the problem since.
In your case, if bone stock, just a fluke defective bulb. If aftermarket bulbs, maybe upgrade brand... Can't see a wiring issue cause this.
GTO 1
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
