eyelid question
Old Sep 26, 2007 | 03:11 PM
dylan1221's Avatar
eyelid question
if i painted my eyelids on the outside of my car.
like lets say i did i coat of Krylon Fusion and like 2 coats of Clear coat
would it hold on the outside of the lighttt
Old Sep 26, 2007 | 03:12 PM
SmOKe JeNsOn's Avatar
You would need to sand them with a fine grit sand paper for them to really stick i did a test run on mine with night shades and the 1st wash the peeled
Old Sep 26, 2007 | 03:19 PM
dylan1221's Avatar
dam was just about to do it thanks
Old Sep 26, 2007 | 03:20 PM
SKDR112888's Avatar
yeah that what I did I sanded them a lil then used like spray piant and clear coat and it looks awesome!
Old Sep 26, 2007 | 03:35 PM
dylan1221's Avatar
does it come off in car washes or rain or anytthiungg???
Old Sep 26, 2007 | 03:41 PM
Fresh's Avatar
if you sand them you should prolly wet sand them...but just the part to be painted. i would mask it out first and then sand. spray on several light layers and then hit it with a few layers of clear. this is what i did and it's been a couple of mths now with no peeling.
Old Sep 26, 2007 | 03:49 PM
G3RG's Avatar
wow i was about to do the eyelid thing this weekend, man im glad i found this. im definately gonna sand. how mch sanding is needed?
Old Sep 26, 2007 | 03:51 PM
Fresh's Avatar
not much at all. just scratch it up a lil bit.
Old Sep 26, 2007 | 03:53 PM
cincybalt's Avatar
would the GM color match paint hold up?? anyone know?
Fresh's Avatar
don't see why not... it's for external use.
Old Sep 26, 2007 | 03:56 PM
JRelly's Avatar
It will hold up...its just like the paint on your car
Old Sep 26, 2007 | 03:57 PM
an0malous's Avatar
yes it will. ive done it on 2 sets of lights so far.
these have lasted since i bought the car over a year ago with no problem at all.
Old Sep 26, 2007 | 04:00 PM
cincybalt's Avatar
did you sand yours?? and i dont realy know how to wet sand
Old Sep 26, 2007 | 04:02 PM
dylan1221's Avatar
an0malous the gm paint or the krylon and clearcoat
where would i get gm coolor match paint
Old Sep 26, 2007 | 04:11 PM
an0malous's Avatar
at your GM dealership
I just used black paint. black is black lol.
yes i did some sanding, but not a huge amount.
just a good healthy number of clear coats.
Old Sep 26, 2007 | 07:41 PM
Fresh's Avatar
wet sanding is basically that. spray water on the light and sand ;-)
Old Sep 26, 2007 | 08:40 PM
Switt23's Avatar
^^ Making sure that the area is always wet while sanding, otherwise it might scratch.
Old Sep 27, 2007 | 08:04 AM
Fresh's Avatar
exactly, spray the hell out of it. almost constantly. then dry it off real good. after that i always use isoprophol alcohol on a rag and wipe the surface off. this gets it good n clean and ready to paint.
at this point you'll spray several light layers waiting a few mins in between each spray. then spray a few light layers of the clear coat. with the paint still wet very carefully pull off the tape. you want to take the tape off while the paint is still kinda wet otherwise if the paint has dried you risk the chance of peeling the paint off when taking the tape off and trust me you don't want to have to deal with that headache! good luck and post pics of finished product
Old Sep 27, 2007 | 03:23 PM
2006BlackSS/SC's Avatar
when i did my eyelids i did not sand and used spraycan of black pain from walmart no sanding here and no peeling at all and i sprayed the hell outta clear so it should work if u sand or not if u want to risk peeling do like i did next time i will wet sand my headlights
Old Sep 27, 2007 | 07:13 PM
Swan SS's Avatar
I just finished mine about two weeks ago, and it is definatley worth the time and patience to do it right. They look awesome! I sanded down the section for the eyelids, primed it with a few light coats, then used the GM matched spray paint followed by a couple of clear coats. Best way to go... i'll try and get a few pics up here tomorrow.
Old Sep 30, 2007 | 02:15 PM
MrsMaris's Avatar
wow so you sand the lights? i never would have thought to sand it. what does the sanding do? prevents from peeling?
I'm really iffy about doing permanant things to my car seeing as if i screw up im stuck paying for new lights and im on a tight budget and I dont want to drive around with funny lights, let alone spend even more money than i have to because of a stupid mistake.
what does the sanding do when you dont paint over it? is it like bumpy or scratchy or anything?
Old Sep 30, 2007 | 02:20 PM
an0malous's Avatar
it will scratch up the surface and leave it cloudy, but what it does is give the paint a rough service to adhere to, to prevent flaking/peeling down the road.
paint doesnt stick as well to shiny or non-porous materials.
Old Sep 30, 2007 | 02:30 PM
sPeEdInGsS's Avatar
i just did my eyelids yesterday. i went to walfart and got some krylon fusion, and clear coat. alls i did was clean the area that was to be painted, then put a couple of coats of fusion and clear and let it dry for an hour. then i installed them back on the car and took it to be washed. it looks amazing. definately better than paying 30-60 bills for them!
Old Sep 30, 2007 | 02:32 PM
2.4SlowassBalt's Avatar
i did not sand my light at all and i have had the eyelids on for over a year, the still look great!
all i did was clean it really well with windex and alcohol and its been good.
here is a pic!
Old Sep 30, 2007 | 02:37 PM
MrsMaris's Avatar
your eyelids look great 2.4slowassbalt.
I guess it all depends on the taste. I might sand just a tad bit.
which eyelid shape looks the best I've seen a few different kinds but i just cant decide.
I like An0malous's lights but maybe his look different because its a view from above.
