FlameThower Exauhst
I recently purchessed a flamethrower exauhst kit from www.eatmyflames.com for my 2007 cobalt LT and am having trouble wiring it up. It came with very vauge directions that are semi understandable. Im no dummy when it comes to wiring and have figured it all out exept for two things. I need to know where and what wire is the ignition wire or if i could just splice off the one going to the radio, also it calls for a negitive wire from the distibuter cap.... Where can i find a wire of equal signifigence on my coblat. If any one has any ideas or any wiring diagrams for the ignition system for the cobalt it would be greatly apreaciated.
Thanks
Wow I came across this while browsing, this might anser the second part.
https://www.cobaltss.net/forums/show...ht=distributor
Hey found some leads on grounds and ignition wires. Im going thru with it, wish me luck and ill try and post a how to here shortly.
just incase im wrong tho and you know for sure what wires to use, feel free stop me before i kill myself... or worse... my car.
Thanks
hey umm read the info about the product before you go on a rant okay.. it says will work with a cat however the flame will be not nearly as impressive.. or they even mentioned wait till your cat's effectiveness fades then it will give a bit more flame
