Fog light wattage???
Old Dec 10, 2007 | 01:16 AM
rickets112002's Avatar
I did a search but never really found a clear answer...what is the highest wattage fog light bulb that i can use without causing damage to the wires, and is this wattage for light input or output???.....thanks!!
Old Dec 10, 2007 | 01:19 AM
DoubleLP's Avatar
Don't change your wattage higher then factory recommended. You are asking for problems with melting wiring. It has happend on here with other people more then once. I believe the stock rating is 55W. And the wattage is light OUTPUT.......I believe.
Old Dec 10, 2007 | 01:20 AM
an0malous's Avatar
55w bulb
IMO you should never draw more wattage through stock wiring.
if you do want to run higher (which is illegal btw) i would consider rewiring the headlight power wiring to handle the higher juice.
Flames coming out your hood one day isnt worth the risk.
Old Dec 10, 2007 | 11:31 AM
thanks
Old Dec 10, 2007 | 10:46 PM
draw or output is what i meant to ask...all the ones i find have a draw of 55w but output of around 100w
Old Dec 11, 2007 | 12:08 AM
Sharkey's Avatar
keep in mind going with a higher wattage bulb, even if wired with relays, can cause damage to the housings, it will melt them. from what ive read, you can put h11 hids in the stock driving lights (they are driving lights, fog lights are yellow) without them blinding oncomming cars.
Old Mar 27, 2008 | 01:11 AM
07cobalt07's Avatar
Sorry for the thread revival... but I need to make sure of this before putting a set of driving lights in my '07 balt. Is the 100W output too much for stock wiring with a 55w draw?
Old May 26, 2008 | 04:21 PM
Xenozx's Avatar
bumped,
55w 80w output OK for stock wiring?
Old May 26, 2008 | 04:34 PM
InfinityzeN's Avatar
55w input. Don't worry about the output since that is not how much wattage it is pulling.
Old May 27, 2008 | 10:15 AM
Xenozx's Avatar
Thanks all I needed to know
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
