Fog lights
i imagine you could splice the wire into the correct one that turns on the headlights in the first place, but im not a wiring guy so cant tell you specifically how to do ti. i just want to have the ambers stay on the DRL setting when the fogs are on.... dont know how to do that
Are you serious? Is it THAT difficult to just press the button to turn your foglights on??? I mean hell, even if you found away to make them come on with the headlights....im sure that would require more work than just pressing the button.
I just figured it would be something different to do, and its not that its difficult to push the button at all
I just figured it would be something different I could probably fool around with it but im not that good with electricity so I figured I would throw something out to see if someone has done it...thanks for the input
Im glad one person feels my pain, i just dont see why GM couldnt have made them come on with the headlights in the first place..
Last edited by ruhland287; Jun 22, 2008 at 07:59 PM. Reason: Automerged Doublepost
dude the button activation of foglights is awesome. i can only run my fogs with my headlights on in the SpecV, and i dont even have DRL. i wish i had a button.
it would be easy to run the fog wires to the wiring harness for the DRL in the balt, just take out the headlights and reach down, pull out your fog harness and splice and connect. but your fogs would run all the time. or you could wire them to the low beams, then the fogs would only come on when you turn the heads on, or when the auto lights come on.
z28addiction
Sep 28, 2015 12:03 AM
