Frustrated over HID
Old Oct 31, 2008 | 08:28 AM
methodman2424's Avatar
Frustrated over HID
Well I got a decent HID kit installed. After I hooked it up one light flickers so I ordered a wiring harness from 3bsec and installed and still having the same prob. I switched the bulbs and it still happens on the driver side. The hearness has a 20 amp. Maybe put a 30 in. Please help.
Old Oct 31, 2008 | 08:31 AM
originaladrian's Avatar
u might need to replace ur relays
i have HIDs but hardly any harness is used. direct grounds and such for better connections. i wouldnt trust tht thin wire
Last edited by originaladrian; Oct 31, 2008 at 08:31 AM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 12:24 PM
Terminator2's Avatar
Check your ground first. If that is good try switching the ballasts if the problem follows the driverside ballast you have a bad ballast. If not it is a bad connection somewhere between the ballast and the bulb. It could also be a bad relay, but I doubt it because you would most likely be having problems with boths sides since they are connected to the same relay.
Old Oct 31, 2008 | 12:32 PM
glen229's Avatar
pull the DRL fuse
Old Oct 31, 2008 | 01:25 PM
Originally Posted by glen229
pull the DRL fuse
yes, but this is only for extra protection so ur HIDS dont turn on and off randomly and screw them up.
Old Oct 31, 2008 | 02:05 PM
glen229's Avatar
its also so that the drivers side doesnt flicker
Old Oct 31, 2008 | 02:28 PM
pull the DRL fuse
Good idea, I didnt think of that.
Old Oct 31, 2008 | 03:43 PM
glen229's Avatar
Old Oct 31, 2008 | 03:57 PM
? hmmm... i had mine in for a long time... why would it cause an HID to flicker????
Old Oct 31, 2008 | 03:58 PM
G85 SS's Avatar
The flicker could be from the ballast as well....
Old Oct 31, 2008 | 04:02 PM
glen229's Avatar
i have no idea why it causes it not to flicker but ive searched through alot of threads and it works
Old Oct 31, 2008 | 04:03 PM
HackAbuse's Avatar
bad ballast gets my vote
Old Oct 31, 2008 | 04:06 PM
DRLs run on 7 volts not the normal 12.6-13.8V that low voltage causes the ballasts output voltage to drop that is why they flicker.
X2. Try switching the ballasts like I suggested and see if the problem follows the ballast from the driver side. If it does bad ballast if not check wiring.
Last edited by Terminator2; Oct 31, 2008 at 04:06 PM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 04:37 PM
So pull the drl fuse first? Yeah i switched ballasts but it still coming from the driver side. Imma go pull that fuse.
Old Oct 31, 2008 | 04:40 PM
glen229's Avatar
yeah that should fix it
Old Oct 31, 2008 | 04:42 PM
mkulrey13's Avatar
Glen....MIGHT know something?
Old Oct 31, 2008 | 04:45 PM
Psykostevo's Avatar
I use 30amp 12v relays for the HID kits I install. No flickering and they fire up everytime.
Old Oct 31, 2008 | 09:07 PM
wardzach2007's Avatar
My ballast used to do that a long time ago on my lancer. It used to get on my nerves. But it only happened once or twice every time I drove. So I got used to it.
Old Nov 9, 2008 | 03:50 PM
so wht fuse is the DRL fuse?
theres not one marked DRL
Old Nov 9, 2008 | 03:55 PM
steddy2112's Avatar
El click for future reference
Old Nov 9, 2008 | 03:56 PM
DoubleLP's Avatar
Should be in the middle of the fuse box under the hood. It is a 10A RED colored fuse.
Old Nov 9, 2008 | 04:02 PM
ill go look one sec. ill bring my fuse box cover bak so i can tell u wht i see lol
no drl fuse
i have a 10 amp park/nutral fuse
tht it?
Last edited by originaladrian; Nov 9, 2008 at 04:02 PM. Reason: Automerged Doublepost
Old Nov 9, 2008 | 04:17 PM
DoubleLP's Avatar
Nope.
Old Nov 9, 2008 | 04:21 PM
here i can list every 10amp fuse in my engine fuse box theres not that many
10amp onstar
10a cnstr vent
a/c clutch
abs2
prk/neut
back up
inj
horn
r hi
l hi
r lo
l lo
emisn
Old Nov 9, 2008 | 04:23 PM
DoubleLP's Avatar
Well isn't that just fun. Is there possibly a relay that is marked DRL?
