Glossy tinted tails...how?
Old Jan 9, 2009 | 08:51 PM
hilty003's Avatar
looking for a lil advice how to get the real glossy tinted tail from vht spray. i dont want the smoky rough looking tails. im only gonna do a few coats, 3 maybe. do i sand first then spray then sand... so i sand the last coat before the clear? do i sand between clear coats? paper grit? im tired of looking through threads. thanks.
Old Jan 9, 2009 | 08:54 PM
RedEcotecSS's Avatar
wet sand 2000 then 3000 grit then **** loads of clear
Old Jan 9, 2009 | 09:56 PM
hilty003's Avatar
that it? do u have any pics of this on yours by chance?
bump. kinda workin on this now
Old Jan 9, 2009 | 09:59 PM
ZeeBee's Avatar
thick and heavy clear, without running
Old Jan 9, 2009 | 11:31 PM
Cobaltxfe09's Avatar
spray nightshades a few times let dry in between about 15 min then clear the same way.thats what i did.
BTW I think there is about 152,958 threads on TINTED TAILS already just sayin
Old Jan 10, 2009 | 12:08 AM
hilty003's Avatar
so you didnt sand at all? yours look good. thats what i want. and i know theres 152,958 threads already. i read through parts of sum didnt find what i was looking for so this was fastest. i can always just delete this when im done. thanks for not flipping tho.
Old Jan 10, 2009 | 12:36 PM
hilty003's Avatar
bump...now ive heard 2 completely different suggestions.
do i sand before i spray or just clean the surface and spray?
do i sand between coats?
heavy or light coats?
sand last coat before clear?
sand between clears?
sorry, im kinda new to painting.
Old Jan 10, 2009 | 12:45 PM
2fastSS's Avatar
a very light coating of sanding is needed then use soap to clean them up and go to town.... the trick is to use clear lightly in the beginning but heavy in the end but heavy to a point where it doesnt streak
Old Jan 10, 2009 | 01:26 PM
hilty003's Avatar
ok good tip, thanks.
Old Jan 10, 2009 | 04:54 PM
i lied i did lightly sand before i painted them just to roughen up the surface first so the tint could stick but after that i just sprayed, let dry sprayed, and so on.
Old Jan 10, 2009 | 06:24 PM
hilty003's Avatar
i actually just got done with them. they turned out the way i wanted too. thanks for all the lil tips guys. hey xfe, do u ever get cops giving u trouble about yours?
Old Jan 10, 2009 | 06:27 PM
:knocks on wood: not yet
Old Jan 10, 2009 | 06:29 PM
hilty003's Avatar
lol alright just wondering. ill get some pictures up eventually. i only did the side markers and third brake light caz i plan on buying the modern performance smoked led tails.
SSnRXP
Dec 4, 2015 11:02 PM
dieGone
Sep 23, 2015 10:20 AM
Aug 29, 2015 03:11 PM
