grille removal
Old Dec 23, 2010 | 06:26 PM
thecobaltguy's Avatar
grille removal
does anyone know how to remove the front grille without removing the bumper or is this possible. I didnt see a thread in the how to guide excpet bumper removal.
Old Dec 23, 2010 | 06:58 PM
arkkornkid's Avatar
no need to remove bumper: take out the top tabs that hold it on, pull up and reach down to remove the nuts that hold the bowtie on. if I remember right there are a few tabs on the center bar that you'll have to deal with, and then once it's free you can pull it out form the top
Old Dec 23, 2010 | 08:07 PM
SS-Performance-RS's Avatar
If you go to the how to's theres a write up there.
Old Dec 28, 2010 | 11:51 PM
the tabs are a pain in the ass and i dont want to break them
Old Dec 28, 2010 | 11:54 PM
EXsoccer1921's Avatar
theres also two plastic screws, one on each side, right next to the headlights. you can get to them without taking the lights out but taking them out makes it soooo much easier overall, not just for those screws. you can take them out with your hand. i did it with a friend and we had them switched out in about 5min. taking the headlights out will help though..
Old Dec 28, 2010 | 11:59 PM
screws that will aid in taking out the grille....i cant get the tabs to loose cuz i dont really want to break them but i will check these out.
Old Dec 29, 2010 | 12:15 AM
no, screws that have to come out...theyre part of the grill.
take off the headlights, look inside. you'll see
Last edited by EXsoccer1921; Dec 29, 2010 at 12:15 AM. Reason: Automerged Doublepost
Old Dec 29, 2010 | 01:12 AM
Trust me the tabs are very flexible I damn near bent the damn things backwards
Old Dec 29, 2010 | 01:14 AM
blackss2.0's Avatar
pop all the tabs out that you can find and there's two black screws near the headlights.
Old Nov 30, 2014 | 08:23 PM
cobaltssdude420's Avatar
removing grille pins
How the f*ck am I supposted to remove these stupid plastics pins that hold the grill in place? i've tried needle nose pliers, a flat head screw driver and even vice grips but I cant get em off....
Old Nov 30, 2014 | 09:00 PM
Theres nothing that you remove to pop the grille off. You push the tabs down behind the grille in order to push it back, then you pull it up and out
Old Nov 30, 2014 | 10:19 PM
rains_crusader's Avatar
If you're talking about the push-pin/clips along the top edge on the upper radiator support, you have to use a small screwdriver and lift the center of the pins then you can remove the clips. There should be 4 or 5 of them. I didn't have any screws anywhere holding my grille in. Just the tabs along the sides, bottom and crossbar and you have to remove the bow tie emblem
chefhhr
Oct 26, 2015 10:36 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
ROADKONE
Sep 9, 2015 02:32 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
