head light help!!!!!!!
how the **** do you get the headlights off our cars?? i unscrewd the 10mm bolts but i can get the dam thing out!!!! help please i gotta work in an hour!!!
cmon need help asap!!!!!!!!!!!!
there is two push in clips at the corner of the grill by the headlight. take those out and you'll be able to pull out on the grille enough to get the light out. you'll still have to push in a lil on the corner of the headlight closest to the grill thou.
Makes you want to throw it like a shot put.
lol gettin it back in can be a bitch some times.. you'll almost have it when you realize the lil clips thats on the bottom of the light isnt lining up and wont let the light go in.. at that point its a bitch to get it to come back out so you can get the lil clip to line up..
Once you get the hang of it it's real easy to do, you just have to know which way to push and pull. I can remove both my headlights in about 30 seconds, usually without having to pull the pins by the grille.
sucks for u. i have no problem doin mine. wut kinda fogs u puttin on?
that was ment in a funny haha joke way. i read it and it kinda sounds like im coming off as a dick. my bad.
its a bitch and I always forget the way i figured out by the time i go to do it again lol I think I saw it about, just push the inside part in and wiggle, removing the pins holding the bumper and pushing the flat part below the headlight down helps too.
so i finnally got them out last night after work at 9pm lol. i didnt knw there were two little clip/guide things on the bottom of the headlight.... i broke one of them off on the pass. headlight.... whatever it still stays in there fine tho.
anyways i got the bulbs changed out, just put in some ebay 8000k halogens xeon (sp?) u get the idea
i dnt have pics yet and wont have them til later 2night perhaps...
i was a little bit dissapointed w the light output but i guess thts what i get for getting them on ebay lol... i do lilke them tho, i prefer the more white/blue light
so i finnally got pics... here they are
Low Beam
High Beam (not much different)
im disappointed in the light output but thts what i get for $20 ebay bulbs lol
light will be better once i install my fogs tho! then i wont have to drive around all the time on high beams!! haha
Low Beam
and to the OP just do what everyone else has been saying and you will be fine.
very true. i liked my 98 s-10. just pull to clips up and the headlight will fall out.. so much easier when it comes to bulb changes or new headlights.
OP the output of those new bulbs you got doesnt look to bad.
